| Author |
Message |
OMalley
Vehicle: 2001 M18a Jimny
 Posted: Thu Nov 25, 2010 8:36 am |
I don't know much about Diff Breathers but I do know they're pretty much essential. I've been looking around for kits, trying to avoid using garden hose.
Have come across this kit, just wondering if the hose in it is the right diameter, as i have no idea..
http://cgi.ebay.com.au/Diff-Breather-Ki ... 2304wt_907
Thanks in advance.
S13RR4
Joined: Sat Aug 22, 2009 11:30 pm Posts: 1072 Location: Sunshine Coast
 Posted: Thu Nov 25, 2010 8:46 am |
dont use garden house. use fuel line. bought from your local super cheap or repco etc,
look at Jason's (want33's) build or Rushos or mine.
few pipe clamps, some fuel line, and some fuel filters, easy and really effective
as for your question about diameter... I dont know, tape measure or wait for someone on here to respond
royce
 Posted: Thu Nov 25, 2010 8:47 am |
nope, if you dont like garden hose get 1/2" Oil resistant TP hose
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Thu Nov 25, 2010 8:51 am |
Whats the TP stand for?
_________________ Watch out or you'll get sued.
royce
 Posted: Thu Nov 25, 2010 8:53 am |
just what its called, there should be a number after it depending if its food grade or not but I cant remember what it is
PJ.zook
Joined: Sat Oct 24, 2009 10:30 pm Posts: 845 Location: Melbourne
There is nothin wrong with good quality garden hose, works fantastic on mine and is the perfect size for all the breather nipples. Plus you can get plastic angles, etc... for it.
bohuler
Joined: Wed Nov 10, 2010 9:18 am Posts: 1376 Location: Avonsleigh, Victoria
 Posted: Thu Nov 25, 2010 8:54 am |
i used 10mm air hose from my standard n/t 1.3 diffs to 2 fuel filters. works a treat and yet to see any water in the diffs
_________________ Life's short, fiddle with your willy while you can
stockman
Vehicle: 4wd
 Posted: Thu Nov 25, 2010 8:55 am |
royce wrote: just what its called, there should be a number after it depending if its food grade or not but I cant remember what it is
Is it automotive? or something from bunnings?
royce
 Posted: Thu Nov 25, 2010 9:03 am |
stockman wrote: royce wrote: just what its called, there should be a number after it depending if its food grade or not but I cant remember what it is Is it automotive? or something from bunnings?
More industrial, ask a hose supplies place for the clear reinforced hose with the Blue and Yellow stripe down the side
stockman
Vehicle: 4wd
 Posted: Thu Nov 25, 2010 9:04 am |
cool. thanks for that.
hutch
Joined: Sun Nov 30, 2008 10:30 pm Posts: 1213 Location: SW Bris
 Posted: Thu Nov 25, 2010 8:09 pm |
Im using garden hose... rather save my money for other shit.
Oh if you want to remind me to post here in another 5 yrs time when the garden hose fails (supposedly). I can then whip another bit off the end of the hose.
"sausage down a hallway"
_________________ 255 characters
OMalley
 Posted: Mon Nov 29, 2010 7:22 am |
Thanks guys, but i think this Oil resistant TP hose sounds like the go. Will grab some this week.
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Mon Nov 29, 2010 7:42 am |
I used 1.5mts of transmission hose, a couple of clamps and a cheap generic plastic fuel filter. total cost $8
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Mon Nov 29, 2010 8:50 am |
hutch wrote: Im using garden hose... rather save my money for other shit. Like rebuilding the diff that failed because of the broken breather.
PVC breathers do fail. I've seen it. It takes less than 5 years. Garden hose is for gardens. That's because gardens aren't oily. OR hot and oily, and in any case, how many times have you had to cut back and shorten a garden hose because the end at the nozzle went stiff and the coupling fell off, and that's only in a garden, not under your car.
Whatever. The OP knows what to use.
lordfury007
Joined: Mon Sep 28, 2009 11:30 pm Posts: 298 Location: Darwin, NT
 Posted: Mon Nov 29, 2010 9:06 am |
Gwagensteve wrote: Garden hose is for gardens. That's because gardens aren't oily. OR hot and oily, and in any case, how many times have you had to cut back and shorten a garden hose because the end at the nozzle went stiff and the coupling fell off, and that's only in a garden, not under your car.
+1
_________________ 1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
bazook
Joined: Sat Jul 12, 2008 11:30 pm Posts: 1082 Location: brisbane logan
 Posted: Mon Nov 29, 2010 9:32 am |
i used air compressor hose and just soften the ends with boiling water
hutch
 Posted: Tue Nov 30, 2010 7:59 am |
Gwagensteve wrote: hutch wrote: Im using garden hose... rather save my money for other shit. Like rebuilding the diff that failed because of the broken breather. PVC breathers do fail. I've seen it. It takes less than 5 years. Garden hose is for gardens. That's because gardens aren't oily. OR hot and oily, and in any case, how many times have you had to cut back and shorten a garden hose because the end at the nozzle went stiff and the coupling fell off, and that's only in a garden, not under your car. Whatever. The OP knows what to use. Steve.
prove it.
JrZook
 Posted: Tue Nov 30, 2010 8:01 am |
lordfury007 wrote: Gwagensteve wrote: Garden hose is for gardens. That's because gardens aren't oily. OR hot and oily, and in any case, how many times have you had to cut back and shorten a garden hose because the end at the nozzle went stiff and the coupling fell off, and that's only in a garden, not under your car. +1
+20
_________________ Lil Foot!
honks
Joined: Tue Apr 20, 2010 11:30 pm Posts: 214 Location: ipswich
 Posted: Tue Nov 30, 2010 9:36 am |
bit of a high jack but what fitting is needed to be screwed into the diff to attatch the hose to
Gwagensteve
 Posted: Wed Dec 01, 2010 5:06 am |
It's normal to just pop the cap off and slip the hose over the stub that remains attached to the diff - that's why people use garden hose - the approx. 1/2" bore slips over the stub pretty well.
If you want to get bling, you can cut the stub down a bit and tap it with a 1/8" BSP tap and then use a proper brass fitting and smaller diameter hose. This is more work and raises the possible issue of steel shavings making their way through the diff.
Hutch - I don't need to "prove it"- It's science. PVC is not oil resistant. Ify ou want to do the experiment, pop some garden hose in a jar with some gear oil. You'll be surprised how quickly it goes all funny.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Wed Dec 01, 2010 5:15 am |
hutch wrote: Im using garden hose... rather save my money for other shit. Oh if you want to remind me to post here in another 5 yrs time when the garden hose fails (supposedly). I can then whip another bit off the end of the hose. "sausage down a hallway"
ok Ill prove it
brand new nylex premium hose on my diffs has cracked in less than 18 mths.And the rest in the garden is still nice and soft.
oh yeah it was new when I fitted it as I chopped it off a new coil I bought for the house.
your diffs do what you like, but I can assure you there is no pvc hoses on your car from factory.
hutch
 Posted: Wed Dec 01, 2010 8:47 am |
Gwagensteve wrote: Hutch - I don't need to "prove it"- It's science. PVC is not oil resistant. Ify ou want to do the experiment, pop some garden hose in a jar with some gear oil. You'll be surprised how quickly it goes all funny.
OK I will try that experiment. I will take photos along the way to.
My point about tyhe garden hose was it is cheap and easy to fit and that commercial diff breather Kit for $100 would buy a shit load of gaden hose.
Just a side question... why does ARB use PVC hose on their airlockers? I have ARB lockers both front and rear and both aree blue PVC hose. I spoke to the ARB head mechanic and he stated the Hose idea was bloody great. He stated it was a muche better option than rubber hose which perish.
ajsr
 Posted: Wed Dec 01, 2010 9:43 am |
hutch I dont think that blue air line is pvc.
it a nylon type thing I think.
my cherry pickers use a very similar product to my air lockers and its definately nylon on the pickers.
foolsp33d
Joined: Tue Mar 11, 2008 10:30 pm Posts: 2123 Location: Deep Inside Jamies Mouth
Vehicle: Clown Car..
 Posted: Wed Dec 01, 2010 9:51 am |
_________________ Roads... Where we're going we dont need Roads....
Gwagensteve
 Posted: Wed Dec 01, 2010 10:09 am |
ajsr wrote: it a nylon type thing I think.
Bingo - it's nylon, not PVC.
royce
 Posted: Wed Dec 01, 2010 10:19 am |
foolsp33d wrote: http://www.austrahose.com.au/resources/PVC%20HOSE.pdf
TMP II by this link is what you need
looking forward to gmans explanation as to why this PVC hose is widely listed as fuel and oil safe, its Science afterall
Gwagensteve
 Posted: Wed Dec 01, 2010 10:32 am |
The composition of the clear inner tube isn't specified. It may well be "pvc" but it might not be too, even though it's referred to as PVC hose.
Your point is a fair one Royce - but you've read an application guide and chosen a suitable product. That's not going to bunnings and grabbing a reel of garden hose and then claiming it's the best thing to use because it's cheap.
PS I've seen clear PVC of that type used and I'm not crazy about it's flexibility. Id be using a barb and 6 or 8mm diameter hose if I was using that type of PVC from my experience- it's easier to fit and holds tighter radii without crimping.
royce
 Posted: Wed Dec 01, 2010 10:35 am |
there is no inner liner on that stuff, thats why its not listed, I dont think its oil that kills garden hose, its the heat cycling
if you go to teh right place this stuff is $1 a meter so cheaper than garden hose, it will stay put on teh factory diff 'tail' really well too, the hose doesnt really deform and it doesnt soften with heat
Gwagensteve
 Posted: Wed Dec 01, 2010 10:42 am |
royce wrote: there is no inner liner on that stuff, thats why its not listed, I dont think its oil that kills garden hose, its the heat cycling
Not picking an argument Royce, but from the app guide, Coldflex, TMPII and Garden hose all have the same temperature range. 0? to 60?
I think it's quite reasonable for a diff to exceed 60? - I know my shaved vitara rear diff gets way to hot to hold your hand on after cruising.
I agree the heat cycling is an issue, but there must be a difference in composition for the TMPII to be rated for oil. Note the outer and inner are both listed as "clear" for the TMP II, that doesn't mean they aren't different compositions though.
Gwagensteve
 Posted: Wed Dec 01, 2010 10:43 am |
