| Author |
Message |
RUN.10W
Joined: Mon Sep 20, 2010 7:17 am Posts: 211 Location: sydney
 Posted: Wed Dec 01, 2010 4:54 am |
Does anyone know of any shops around Sydney that stock or supply 15x8 or widder sunraiser rims for a Suzuki Sierra? I can't find a single place that has them and have rang so many places, best I can find is 15x7 which won't work with my Tyres any help will be greatly appreciated thank you.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Wed Dec 01, 2010 4:55 am |
ask for F100 rims
suzi-fan-22
Joined: Tue Nov 09, 2010 9:31 am Posts: 499 Location: Ipswich
Vehicle: Sierra Ute '87 Sj70
how big of tyres are you running?
_________________ It's all coming together
RUN.10W
 Posted: Wed Dec 01, 2010 5:17 am |
33x12.5
_________________ 96 coily, lifted, locked,geared, 33's.
DRV31T
nato78
Joined: Fri Apr 09, 2010 11:30 pm Posts: 1504 Location: Auckland, NZ
Vehicle: Yamaha scooter, 50cc
 Posted: Wed Dec 01, 2010 7:21 am |
Anyone who sells kings wheels will be able to get a set in for you, I'm running 15x8 steelies on mine with -30 offset, I think they do a -50 offset too
LAY80N
Joined: Tue Jul 28, 2009 11:30 pm Posts: 455 Location: Newcastle NSW
Vehicle: I drive your mum
 Posted: Wed Dec 01, 2010 8:04 am |
Why do you need wider than 8 inch?
Layto....
Fatzook
 Posted: Wed Dec 01, 2010 8:12 am |
LAY80N wrote: Why do you need wider than 8 inch?
Layto....
33x12.5's fit on an 8" rim, but a 9 is better.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Wed Dec 01, 2010 8:21 am |
^^ fancy pants!
RUN.10W
 Posted: Wed Dec 01, 2010 8:56 am |
I like them rims  bigger offset the better, I just can't find any one that stocks them or can get them in in the size I want
DRV31T
Fatzook
 Posted: Wed Dec 01, 2010 9:37 am |
RUN.10W wrote: I like them rims  bigger offset the better, I just can't find any one that stocks them or can get them in in the size I want
Any reason why you are wanting 15's? 17's come in widers sizes.
PeterW
Joined: Tue May 18, 2010 10:30 am Posts: 105 Location: Albany WA
 Posted: Wed Dec 01, 2010 10:18 am |
That was a sweet looking rim
smiffkid
Joined: Fri Aug 13, 2010 12:55 pm Posts: 3266 Location: perth wa
 Posted: Wed Dec 01, 2010 10:57 am |
dynamis do a 15x8 -22 or -25
procomp do a 15x8 -50
and i think if u wanted to go with a max offset u can order a outer from dynamic any size u want and then weld your centre in.
boss's patrol rims are like -90
_________________ dodgy brothers mechanical
RUN.10W
 Posted: Wed Dec 01, 2010 5:10 pm |
Thanks mate will make some phone calls greatly appreciated
DRV31T
RUN.10W
 Posted: Wed Dec 01, 2010 5:24 pm |
Fatzook, I need 15's due to buying new rims and tyres which are 33x12.5'on 15, the place I got my stuff from put the tyres on hilux sunraisers which isn't going to work on a Sierra and lost the recipe saying Sierra rims so I have to look else where for Sierra rims and swap them over. Otherwise 17's would be nice....
DRV31T
Fatzook
 Posted: Thu Dec 02, 2010 12:04 am |
pooh. Ohwell.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Thu Dec 02, 2010 1:32 am |
Fatzook wrote: LAY80N wrote: Why do you need wider than 8 inch?
Layto.... 33x12.5's fit on an 8" rim, but a 9 is better.
very pretty pete
I take it these are more show than go rims ,with a fake beadlock?
who made these for you?
atari4x4
 Posted: Thu Dec 02, 2010 1:37 am |
ajsr, i reckon they're a TSOR prototype that he made up a while ago.
Fatzook
 Posted: Thu Dec 02, 2010 1:51 am |
ajsr wrote: very pretty pete I take it these are more show than go rims ,with a fake beadlock? who made these for you?
Show AND go
They are just bead strengthening rings. They are setup to run internal beadlocks.
The centres are 12mm 350_FMS. The wheels are Jig welded and faced both sides so that they run true.
Perfect buggy wheels.
And as Atari said, these are TSOR customs.
royce
 Posted: Thu Dec 02, 2010 1:58 am |
Are the gunna let go in the middle like a similar design by a prominate tyre shops rims have been known to
Fatzook
 Posted: Thu Dec 02, 2010 2:02 am |
royce wrote: Are the gunna let go in the middle like a similar design by a prominate tyre shops rims have been known to
I know the ones you speak of
And the centres were designed in solidworks and run through the stress analysis shit, so I am pretty confident that the improvements I made over the 'Similar' designs are sufficient
royce
 Posted: Thu Dec 02, 2010 2:09 am |
how much does the centre flex as the rim rolls around under load? there would be a fair load on the bends in teh center wouldnt there?
it was found that welding in a flat brace from teh WMS direct to teh rim made them a lot lot stronger
RUN.10W
 Posted: Thu Dec 02, 2010 4:03 am |
Found 15x10 with a -46mm offset for $140 each now I will have brand new hilux 15x8 with a -26mm offset white sunraisers to sell
DRV31T
