It is currently Mon Oct 12, 2026 6:51 am
Post Posted: Wed Dec 01, 2010 11:13 am
whats the easiest way of getting more power out of the g16b.
have a fair bit of room under the bonnet thanks to the body lift so just want to know what your opinions are
Post Posted: Wed Dec 01, 2010 11:16 am
drop $7-10K on a turbo install.
Post Posted: Wed Dec 01, 2010 11:18 am
i think if i had the money i would find a v6 out of a vit and put in it.
i have baleno injectors just thinking if there are any bigger then that and if there is any way to mod the fuel pump so can pump more fuel obviously.
Wouldnt mind a turbo and intercooler tho
dodgy brothers mechanical
Post Posted: Wed Dec 01, 2010 11:19 am
put some of this in the tank
then fit one of these....
Post Posted: Wed Dec 01, 2010 11:20 am
just did it http://www.auszookers.com/index.php?nam ... ic&t=17198
NO DEAL there where no gains whatso ever aside from me gaing a headache from the noise.
Post Posted: Wed Dec 01, 2010 11:21 am
nos it pretty expansive isnt it.
would make it way better on the beach tho, not a bad idea.
might look into that
Post Posted: Wed Dec 01, 2010 11:47 am
its also rather expensive, and for a whole 10sec it might be better
Vehicle: Clown Car..
Post Posted: Wed Dec 01, 2010 11:51 am
even more expensive when ya pour a FIZZY DRINK in a motor that is running ok in a vain attempt at gaining more 'power'
Post Posted: Wed Dec 01, 2010 11:54 am
have been speaking to a couple of guys in malaga.
hoping that we may be able to use 1 of there products and use it on my car. will have to see its on the drawing bored, ill let u know if it works.
Post Posted: Wed Dec 01, 2010 11:59 am
FYI, you're wasting you time chasing more power when you should be fixing the gearing.
Post Posted: Wed Dec 01, 2010 12:03 pm
yea gearing is getting delt with at the moment, figuring brackets now to get the sierra box in
Post Posted: Wed Dec 01, 2010 12:04 pm
x2
any money on gearing is well spent
haha might save having to do the clutch again soon?
Post Posted: Wed Dec 01, 2010 12:11 pm
yea didn really need to slip the clutch on the weekend managed to idle pretty well up most the tracks, the 1.6 helps a lot but will be better with the lower gearing.
only time i slipped the clutch heaps was trying to drive up the log at the end. but the clutch held up well
once you've done the gearing, so long as you gear it right, you wont be wanting for more power (well, ok you will, but you wont need it).
Post Posted: Wed Dec 01, 2010 12:12 pm
haha yea. was spewin that i couldn keep up with u alien on the way home. only way i would of been able to is drop to 3rd haha
Post Posted: Wed Dec 01, 2010 12:23 pm
lol, you have better aerodynamics than me too =)
Post Posted: Wed Dec 01, 2010 12:26 pm
yea i know, well sort of better.
but yes gearing is deffinitly gonna make a difference
Post Posted: Wed Dec 01, 2010 1:09 pm
What made u come out with this idea?? :roll:
Better do some more research, just pumping more fuel aint gonna give you any gains.
Lil Foot!
Vehicle: 93 Sierra
Post Posted: Wed Dec 01, 2010 3:22 pm
Geeze, I didn't know it was a drag race out in front. I'm sure the mighty G13B would have shown you both up :P
...or at least convincing myself it would have keeps a couple of grand in my pocket! :D
Post Posted: Wed Dec 01, 2010 7:17 pm
i have to admit i have always wanted more power, till i got gearing.
do u want it faster on the road or in the bush??
Post Posted: Wed Dec 01, 2010 9:42 pm
power in always good, expecially in sand and on the highway, my car does alot of long trips and beach runs.
but will see how it goes once the gearing is in.
the more air and oxygen u get into the motor the better it will go, wont make a huge increase but it will be a bit better
Post Posted: Wed Dec 01, 2010 9:48 pm
whats the standard jimny tcase ratio compated to sierra box?? running 31's you're up about 20% in tyre size, so if the sierra box isnt a 20% reduction, then you might want some 4.16 tcase gears in the sierra box before you fit it up.
The goal should be to get the jimny as close as possible to stock gearing with the 31s, maybe a touch lower to counter rotational weight of the tyres (although the 1.6 does that).
Post Posted: Wed Dec 01, 2010 9:50 pm
well i think, not 100 percent sure but there is about 15% in high range and 70 or 80 in low. i dnt no but thats what i have been told. ill put it in and see how it goes its only 15 bolt and its out again
Post Posted: Wed Dec 01, 2010 10:52 pm
i wouldnt bother dude... 15% aint enough... chuck in a 4.16 gear set for sure.
http://locktup4x4.com.au/suzuki-sierra- ... s-742.html
$700 well spent i reckon.
Vehicle: '96 LWB trayback
Post Posted: Wed Dec 01, 2010 11:48 pm
As above, gearing is the solution.
Your planned upgrades to fuel (bigger injectors/pumps) will give you zero performance gain and if the car runs at all, it will most likely use too much fuel and run like a pig.
Your factory injectors don't run at 100% capacity as the engine does not breathe enough air to need that.
To make power, you need to get the engine breathing more air then adjust the tune to provide the correct amount of fuel to achieve the stoich AFR.
The easiest methods are intake/exhaust. higher flowing filter, bigger throttle body, cams, ported head, etc.
The harder option is forced induction through it various means, and the dollars and headaches associated with it.
Post Posted: Thu Dec 02, 2010 7:28 am
x 2 fitting bigger injectors and havin no way to supply more air is a step backwards :? it will over fuel and run like shit. also you would have to re map or get a stand alone ecu :roll:
Post Posted: Thu Dec 02, 2010 8:23 am
15 would be plenty for high range alien.
low range is my biggest problem. will see how it goes once its in
Post Posted: Thu Dec 02, 2010 8:31 am
yeah i dunno man... you'll still have the gearing issue going up hills on road at highway speeds... and the 4.16 tcase drops low range 84% over standard sierra - so if you're right about the 70odd% lower standard case then you're headed around a 150% low range reduction... which is spot on! (my 5.14 gears do 183% low range, and i use 1st low a lot!).
Post Posted: Thu Dec 02, 2010 10:42 am
yea will see
gotta make jigs and all sorts of fancy shit so i can set it up for the bracketry.
hopefully it will be in buy our next trip to the powerlines
Post Posted: Thu Dec 02, 2010 12:33 pm
why don't you post up the next powerlines trip when the box is almost done? give me a week or so notice and i should be ok to come along for the big test =)
Users browsing this forum: Google [Bot] and 350 guests
