It is currently Sun Nov 01, 2026 7:16 pm
Vehicle: 91 WT 1.6EFI
Post Posted: Sat Dec 04, 2010 7:58 pm
Ok so I have been using the search function for two days positive there would be something on this topic but I have come up with nothing so here goes.
I'm going to redo the suspension in my WT sierra with commo and hilux shocks and I'm going to have to extend the bumpstops to suit. I'm about to put an order in with lowrange and I was looking at the bumpstop options that they offer. From what I have gathered from the threads that I have been reading, sierras use a 2 bolt style bumpstop? but I have no idea what the stock length is.
I'm pretty sure that I'm going to need at least a 25mm extension on top of the stock length. The only two bolt style bumpstop that lowrange sells is approximately 57mm total (conversion from inches). Will these be big enough? and if they are to big, can I just cut them down until they are the proper size?
I'm planning on removing leaves from the spring packs and running three leaves all around plus fitting the longer travel shocks, do I need to get some extended brake lines?
Thanks for your help :D
Post Posted: Sat Dec 04, 2010 8:09 pm
on the front i just bolted the standard bumpstop to a piece of 30mm rhs which i then bolted to the standard bolt holes. doing it this way i was able to
move the bumpstop forward 50mm the same distance my diff my diff has been moved.
when i get around to it i will just weld a bit of rhs to the pad thing the rear bumpstops touch.
Post Posted: Sat Dec 04, 2010 8:20 pm
so your just saying put a bit of bar under the bumpstop and run bolts all the way through? will this work for the back to? isn't the rear bumpstop on the diff?
Post Posted: Sat Dec 04, 2010 8:30 pm
no, on the front i used RHS with 4 standard sized bolts ie bolted the bumpstop to the RHS
and then bolted the RHS to the original bumpstop mount. if you have moved
your diff forward you need to make sure that the bumpstop doesn't miss the diff.
on the rear just weld/bold a bit of RHS to the pad on the chassis that the bumpstop touches.
you can see the rear bumpstop
front bumpstop.(ignore the brake line.)
Post Posted: Sat Dec 04, 2010 8:56 pm
alright. and excuse my ignorance here but what is RHS?
Post Posted: Sat Dec 04, 2010 8:57 pm
really hard steel.. :P :roll:
Ok, rectangular hollow section..
Post Posted: Sat Dec 04, 2010 9:35 pm
haha ok I see that now thanks steak knife. that bits sorted then. anyone on the brake lines?
Post Posted: Sat Dec 04, 2010 9:39 pm
:P
Or you could get a set of these..
http://www.lowrangeoffroad.com/suzuki/s ... lines.html
Post Posted: Sat Dec 04, 2010 10:53 pm
Yup thats what I was looking at. thanks fellas for your help!
Post Posted: Sat Dec 04, 2010 11:00 pm
:rofl: @ joe & dm90 i think... :lol:
Post Posted: Sun Dec 05, 2010 3:11 am
hay steak_knife the lowrange jobbies are not road legal in aus :wink:
Post Posted: Sun Dec 05, 2010 3:15 am
like that would bother you shep :thefinger:
you would use garden hose if it worked :wink:
Post Posted: Sun Dec 05, 2010 3:46 am
it was a seppo braided line that busted, i had the dodgy line while i was
waiting for some adr jobbies to turn up.
brakes and tyres are the two things i don't like to dodgy up.
everything else is fair game but. :lol:
Post Posted: Sun Dec 05, 2010 5:06 am
I have em & haven't been pulled over yet, so they can't be to bad.. :lol:
:? & I thought they are :?
Post Posted: Sun Dec 05, 2010 5:16 am
narh they have to have a sleeve over the top of the braid to be adr compliant.
my fronts have the sleeve, but my rear flex line is still a seppo jobbie
Post Posted: Sun Dec 05, 2010 5:53 am
Heat shrink should do it then?? :wink:
Post Posted: Sun Dec 05, 2010 8:42 am
dunno. it is a common reason to defect a motorbike. :wink:
Users browsing this forum: Google [Bot] and 56 guests
