It is currently Fri Oct 23, 2026 1:05 pm
Post Posted: Fri Jan 28, 2011 1:20 am
hey guys im trying to get the crank pulley bolt off. it just wont budge. ive tried to lock a breaker bar in place and turn the motor over but that didnt do much. how do u get it off?
Post Posted: Fri Jan 28, 2011 1:23 am
ps. its a coily
Post Posted: Fri Jan 28, 2011 1:24 am
you need to put some heat on it, using a blow torch or something similar. it will make it a lot easier to get off.
Post Posted: Fri Jan 28, 2011 2:06 am
Put a breaker bar on there in such a place that it will hit something solid when the motor spins.
Disconect the lead from the dizzy to the coil so she won't start, then jump in and turn the key...
I want my old sig back :(
Post Posted: Fri Jan 28, 2011 2:12 am
wont that damage the starter?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Fri Jan 28, 2011 2:15 am
Just give it a quick hit, don't keep turning it....
Impact is the best way to remove stubborn nuts and bolts...
Post Posted: Fri Jan 28, 2011 2:31 am
i tried to start the motor with the breaker bar on already. the starter didnt have enough power to loosen it. might have to wait till next week when i go back to work and can bring home a blow torch
Post Posted: Fri Jan 28, 2011 4:42 am
there are 5 bolt's to remove the pully on my coily and the big on doe's not hold the pully
if u drive a loud toyota ute u drink rum
Post Posted: Fri Jan 28, 2011 4:46 am
Good point... Only 4 bolts I think on my WT, but yeah, the big bolt doesn't need to come off to get the pulley off...
Forgot that :P
Vehicle: Nissan
Post Posted: Fri Jan 28, 2011 4:48 am
x2 :wink:
Pearce-toff Racing
Post Posted: Fri Jan 28, 2011 6:09 am
Hi,
If its an early 1 liter motor a rattlegun will do the job. If its never been removed before it will be tight as. The bigger newer motors I haven't had any experience with.
Russ
Post Posted: Fri Jan 28, 2011 7:35 am
let the bar have a bit of swing on the starter but don't be standing to close. heating should be the last resort..
Vehicle: 92wt 1600
Post Posted: Tue Oct 15, 2013 4:27 pm
hey I know this is a old add but after the same help well kinda. I have a g16a with leaking crank seal I want to fix but for the life of me I can not get the pully off it has 5 bolts and I can not find a pully tool that will line up. I have made my own (no good) little heat (no good ) list go's on help me please and thanks
Post Posted: Wed Oct 16, 2013 6:35 am
To remove confusion.
If you only need to remove the belt pulley it is held on with 5 x M6 bolts
If you need to remove the crankshaft pulley make sure you line up the timing marks first
Post Posted: Wed Oct 16, 2013 6:56 am
If you are down to the point that everything is off and you are just staring at a pulley, bolt the fanbelt pulley back on to it and use it to wiggle side to side to get it to slide off.
Post Posted: Wed Oct 16, 2013 9:39 am
^^^ That doesn't always work.
Put the center bolt back, leave it a couple of turns loose and then bolt a piece of scrap flat bar stock across two of the holes and use that to pull it off - center of the bar stock bears against the center bolt whilst you tighten down the two outer bolts.
Vehicle: WT sierra, GU CRD
Post Posted: Wed Oct 16, 2013 11:02 am
:evil: :x True.
I love ZD30. :)
Vehicle: 92wt 1600
Post Posted: Wed Oct 16, 2013 2:34 pm
need to do crank seal so need crankshaft timing pulley off. it will not wiggle off it is a reco engine and starting to think it is loctited on or something. I made a pulley tool out of 5ml flat steel with 5 holes to bolt on to pulley and a nut welded to the centre with a big bolt to tighten on to the loose centre bolt . it just pulled the 5 bolts thru 5 ml. ill try Put the center bolt back, leave it a couple of turns loose and then bolt a piece of scrap flat bar stock across two of the holes and use that to pull it off - center of the bar stock bears against the center bolt whilst you tighten down the two outer bolts.
Post Posted: Thu Oct 17, 2013 9:51 am
Use at least grade 8.8 bolts instead of the ones in the pulley
Vehicle: 92wt 1600
Post Posted: Thu Oct 17, 2013 4:40 pm
ok so got flat steel drilled 3 holes bolted all up over wound out centre bolt still no luck just bending the flat steel????
any other ideas? really want seal fixed
Vehicle: 92wt 1600
Post Posted: Thu Oct 17, 2013 4:42 pm
yar nothing less then 8.8 when eva I replace or use bolts even have 8.8's holding on timing cover
Post Posted: Fri Oct 18, 2013 7:16 am
Get a 12 to 20mm thick piece of steel. One with some guts to it. Spray the back of the pulley with WD40 and leave for a day. Tap it lightly with a hammer all round.
Vehicle: 92wt 1600
Post Posted: Fri Oct 18, 2013 3:31 pm
got the shits with it all back together. it can keep leaking for now. ill try and get some 20mm when I do ill try again might try and find a new pulley to just incase the 20mm don't work and ill cut the bloody thing off. thanks for all ya help every one ill post it up when I get it off and let ya know how I got it off.
Post Posted: Sat Oct 19, 2013 9:22 am
Ok. Here's a hint for when you do get it off. I have used this and swear by it.
there's no guarantee that a new seal will stop an oil leak but this will.
A "Speedy Sleeve". They're about $35 from any bearing shop
Have a look at this
http://www.youtube.com/watch?v=09LiVbqL6ss
Vehicle: 92wt 1600
Post Posted: Sat Oct 19, 2013 11:01 am
cool thanks I like the look of that. would of never looked for something like that. ill get one of them befor my next attempt to fix it to.
Post Posted: Sun Oct 20, 2013 6:55 am
Whoops!!!
I forgot to tell you to take your new seal with you so they can give you the correct Speedy Sleeve
Vehicle: 92wt 1600
Post Posted: Sun Oct 20, 2013 10:20 am
do the sleeve come with tool to fit them. if not how do you fit them? im guessing they are a super tight fit.
Users browsing this forum: No registered users and 156 guests
