It is currently Wed Oct 07, 2026 5:16 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Thu Feb 03, 2011 9:53 am
800rpm i thought?
Post Posted: Thu Feb 03, 2011 1:06 pm
800-900 RPM when arm, but there is a high idle until the car warms up,
Post Posted: Thu Feb 03, 2011 7:49 pm
cool thanks will see if i can find this screw on the throttle body
Post Posted: Thu Feb 03, 2011 8:20 pm
i just had a quick look on mine couldnt find it :oops:
Post Posted: Thu Feb 03, 2011 8:53 pm
i found a flat head on top of the throttle body recessed in but its already all the way in an its idling at 1400 rpm hot any other ideas?
Post Posted: Fri Feb 04, 2011 12:30 am
I had some fun adjusting the idle....took me about 2 weeks to get it right :P hahahaha
The top screw you are talking about is the 'warm' idle when the car reaches working temperature and it should sit at around 800-950rpm
The cold idle is under the throttle cable. You need to turn the car off and then pull the throttle cable up. That will expose another flat head screw and thats your cold adjuster. Turn it right and the idle will go up...left turn is lower the rpm. Start the car and see the idle...should hit about 1000rpm or so when its cold and as soon as you turn the lights on it should rise to around 1200rpm. You need to 'depress' the accelerator pedal (rise the revs) so the accelerator cable isn't 'stuck' (if that makes sense)
You will definatelly need to do this a few times to get it right but remember that you need to adjust your rpm with your lights on....(hot or cold the lights need to be on)
Idle should be around 900-1000rpm with lights on when the car is warmed up and around 800rpm with the lights off.
Someone please correct me if im wrong though :P
Post Posted: Fri Feb 04, 2011 12:36 am
You will definatelly need to do this a few times to get it right but remember that you need to adjust your rpm with your lights on....idle should idle around 900-1000rpm (around 800rpm with lights off when the car is warmed up)
Sound convincing :lol:
Post Posted: Fri Feb 04, 2011 12:39 am
Sorry...just re-edited some RPM figures :p hehehe
Users browsing this forum: No registered users and 166 guests
