It is currently Mon Oct 12, 2026 11:27 pm
Post Posted: Mon Feb 14, 2011 7:01 am
Hey guys I'm having some trouble with my vitara ever since I have had the car it wandered around on the highway quite abit
I have checked:
Tyre pressure
Tie rods and ends
Wheel bearings
steering box tension
Steering column to steering box
The only other thing I can think of is wheel alignment but my other vitara with 60mm lift and no wheel alignment done drives better than the stocko
What's your opinions?
Also has anyone used Dba slotted rotors is it worth it on a stocko
Post Posted: Mon Feb 14, 2011 7:07 am
check for free play in the idler arm bush.
i run RDA slotted rotors in the front of my SV420 & they're a nice upgrade.
Post Posted: Mon Feb 14, 2011 7:10 am
Mine did that after a lift, but adjusting the camber bolts fixed it.
Worth looking at, mines tracks quite well now.
No more white knuckles at speed :)
Ofr course check all steering gear out too.
Post Posted: Mon Feb 14, 2011 7:11 am
i replaced the idler arm bush... genuine suzuki part 8O
the vit had a bit of free play in the steering & you could actually watch the idler arm move up & down on the bush when turn the wheels, the inner sleeve had separated from the rubber... it's like a new car again with the new bush.
it didn't "look" too bad...
didn't take many pics, but i can go out and take a finished pic...
the bush got pressed out & new one pressed in & the idler arm got painted & refitted.
Vehicle: SJ50 hardtop!
Post Posted: Mon Feb 14, 2011 7:25 am
Mine wonders due to my idler arm bush being flogged out a bit. Jack the front up and get someone to shimmy the steering wheel so you can look for loose ends.
NT SJ50
Post Posted: Mon Feb 14, 2011 7:27 am
I'll check that idler arm bush but when I was under it just before nothing seemed to have any free play I had my missus Turing the wheel back and forth
The wandering doesn't feel like free play it feels like it grabs a rut in the road and just wants to follow it until you fight it out and the slightest cross wind affects it
Post Posted: Mon Feb 14, 2011 7:29 am
Get a wheel alignment...
Post Posted: Mon Feb 14, 2011 7:38 am
mine suffered from the same sort of symptoms, it gets regular wheel alignments & replacing the bush fixed it.
Post Posted: Mon Feb 14, 2011 8:42 am
Bush has no movement at all and all steering joints are good wheel bearings have no play.
I'll book it in in the morning for a wheel alignment and see if that fixes it
Post Posted: Mon Feb 14, 2011 8:46 am
If not already fitted, you can buy camber adjustable bolts for the struts
Post Posted: Mon Feb 14, 2011 8:48 am
Yeah but it's only a stocker so it shouldn't need it?
My vitara without an alignment or camber bolts with 60mm lift drives better
Vehicle: LWB Sierra & XL7
Post Posted: Mon Feb 14, 2011 8:56 am
Yeah I get the same sort of feel out of mine, I've got at least an inch of freeplay from the steering wheel. I put it down to worn suspension bush's, shocks and wheel bearings. Once I sort it out I can finally get back to buying goodies for it.
Hey Gus, I don't suppose you made note of the part number for the idler arm bush and price?
Post Posted: Mon Feb 14, 2011 9:06 am
I need to read things proper before commenting :roll:
Missed the stocker bit.
I agree, mine steered better after a lift,
but mine originally had wheels sticking out the bottom like a race car.
Only cos I messed with ride heights a bit,
before settling on suspension work,
and adjusting camber again.
I thought I did have the part number & invoice somewhere in the shed, but the last time I looked for it was after a bit of a tidy up in the garage & it appears that it got filed under "B" for bin, in the big round filing cabinet. :oops:
Post Posted: Mon Feb 14, 2011 9:07 am
Also check your steering shafts and stuff. I don't know about zooks, but we replaced a worn prado one that had worn out the splines and caused excessove play
NT SJ50
Post Posted: Mon Feb 14, 2011 9:18 am
No worries, I'll just have to do it the hard way and give them the VIN number, Rego details, birthday, number of bolts in the car, take in my crayons and draw one for them and learn the sign language for idler arm bush thingy.
Post Posted: Mon Feb 14, 2011 9:31 am
Save ya crayons and use the new age stuff digital cameras
Once I get the wheel alignment done I'll report back
My findings
Post Posted: Tue Mar 01, 2011 9:57 am
How did this turn out.
My idler arm bush is the only old bush left in front end,
could be worth checking, before I do a proper alignment.
Is changing this bush a bugger of a job, or nice n easy ?
Post Posted: Tue Mar 01, 2011 6:50 pm
I got screwed from the place that was meant to do it. Dropped it off 3 days in a row and they didn't touch it and haven't had a chance to take it somewhere else
Post Posted: Wed Mar 02, 2011 4:10 am
Got under mine today, there appearsto be a very small bend
and a tiny bit of movement, in the idler arm bush.
But hard to say if its just the angle I'm looking at it.
May just wait till I sell the next sierra part,
and buy a Heavy Duty one, with a new bush in it.
Could be wise for future tyres and gearing changes anyway.
Post Posted: Wed Mar 02, 2011 4:27 am
the idler arm is a bit "dog legged" from the bush end to the drag link as seen in the pics above.
SiKiD replaced his with a heavy duty idler arm from Sky Manufacturing (I think) & also replace the drag link & tie rod ends pretty much eliminating all the free play.
Post Posted: Wed Mar 02, 2011 4:35 am
It could be a smart idea to do it all together, probably easier too.
Lowrange have one listed now, may even be the Sky one?
http://www.lowrangeoffroad.com/suzuki/s ... r-arm.html
Also a brace I just noticed
http://www.lowrangeoffroad.com/suzuki/s ... brace.html
Post Posted: Wed Mar 02, 2011 4:46 am
The Blue Calamari Idler Arm Brace is for LHD only. The other one is the Sky Manufacturing one that I was talking about, it appears to be one tuff mother farker.
Post Posted: Wed Mar 02, 2011 4:50 am
yeah was wondering about left/right.
The idler arm appears to be ampidexterous.
Easier than changing bushes, too.
I've gone off bushes lately :)
Post Posted: Wed Jul 27, 2011 2:47 am
Inbits did you end up resolving this. I'm having this same issue and am gauging my options of a mild replacement to get it working again or all all out assault on my front end ( although my bank balance would be unhappy about that ). The car both wanders over the road like a fairy and then shudders the rest of the time.....
I'm almost certain its wheel bearing time even without checking them. And steering has a fair amount of play the the idler arm is on the list.
Post Posted: Wed Jul 27, 2011 9:04 am
Mine does that exact same thing too on the highway, feels like it falls in a rut all of a sudden and pulls either way. i thought it might be fucked susp bushes, interested in this idler arm theory.
just found this
http://www.ebay.com.au/itm/1-IDLER-ARM-SUZUKI-X90-X-90-VITARA-SIDEKICK-89-98-/180642035363?pt=AU_Car_Parts_Accessories&hash=item2a0f1ab6a3#ht_2113wt_698
Post Posted: Wed Jul 27, 2011 9:15 am
for another $40 odd bucks you can get a heavy duty one off lowrange.com
Post Posted: Wed Jul 27, 2011 9:41 am
http://www.lowrangeoffroad.com/index.php/suzuki/sidekick-tracker-x90/steering/extreme-duty-idler-arm.html (same as above)
you mean this one? so it will work for rhd?
thier site is saying itll cost 65 to ship wtf?
Post Posted: Wed Jul 27, 2011 9:44 am
I've recently done new suspension to no avail as that was my line of thought. now it lines with steering. done swaybar bushes.
Damn i have to have the idler arm shipped to my us office by Tuesday or wait 3 weeks &*#$ errrr decisions decisions. exchange rate is at 1.10 though
Post Posted: Wed Jul 27, 2011 9:46 am
Will fit our RHD Vits, that is what I fitted to mine, very happy with it.
Self lubricating bush, very niice.
Got mine from roadless gear cheaper than the rest,
http://www.roadlessgear.com/Merchant2/m ... e_Code=RGL
Users browsing this forum: No registered users and 238 guests
