| Author |
Message |
lumpy_zook
Joined: Thu Jan 27, 2011 2:15 am Posts: 108 Location: whyalla
 Posted: Wed Mar 16, 2011 7:29 am |
is there another model of inlet manifold design that will bolt on to a vitara 1.6 16 valve?
the one i have the throttle body is on the back pointing towards the motor
i have seen some with the throttle body on the front, is this from a different model vitara? or something else?
id like to change to the front facing throttle body, as my bonnet would clear everything, if it wasn't for the throttle body in the back..
thanks
mondo
Joined: Wed Dec 29, 2010 10:18 pm Posts: 481 Location: Jimboomba
 Posted: Wed Mar 16, 2011 7:41 am |
if the only reason you want to change the plenum chamber is to clear the bonnet, i think either lowering your motor or doing a small body lift would be much easier. finding a whole new intake for a vitara might be difficult
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Wed Mar 16, 2011 7:42 am |
Baleno
_________________ SJ50.4.LYF
stocker
Joined: Wed Dec 08, 2010 7:16 am Posts: 941 Location: Shidoni!
 Posted: Wed Mar 16, 2011 7:45 am |
depending on what G16B you have. the Baleno Manifold might not fit. i have a Baleno G16B sitting in the garage. and the head has a different style of Port.
_________________ Stocker
lumpy_zook
 Posted: Wed Mar 16, 2011 7:50 am |
craaap...
thanks for all that guys. yea, it is only because of the clearance.
but i dont want to do a body lift and im trying to keep the 1.6 sump, because i dont have anything from the 1.3 anymore.
might have to do a small body lift, just enough for clearance.
thanks again for everyones quick answers..
stocker
 Posted: Wed Mar 16, 2011 7:54 am |
What about some Bonnet Spacers??? how much room are you chasing??
could be a quick cooling mod also
lumpy_zook
 Posted: Wed Mar 16, 2011 1:46 pm |
well, the bonnet sits about 2 inches higher at the grill, but its hitting up the back on the throttle body, so would only need an inch to have clearance.
i recon ill loosen off all the body mounts, and lift it up half inch at a time, until i have clearance.
then just make a body lift at that height.
i want to keep it close to stock appearance from the outside.
Fatzook
 Posted: Wed Mar 16, 2011 1:52 pm |
lumpy_zook wrote: i want to keep it close to stock appearance from the outside.
Then drop the motor. The 1600 MPFI can be fitted UNDER a 1L bonnet. So a 1.3L bonnet is easy! RUF should get you the room you need to leave the stock sump in place. Just move the motor down and back, shorten your jack shaft and enjoy a more stable rig.
Low is where its at
lumpy_zook
 Posted: Wed Mar 16, 2011 1:55 pm |
Fatzook wrote: Low is where its at
yea, this is the reason i was trying to avoid the body lift. my suspension is still stock atm, and i had the motor all bolted in
looks like its going on stands then, il ruf with the rear springs i have in it, drop the motor and then sort out something later.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Wed Mar 16, 2011 10:08 pm |
Fatzook wrote: lumpy_zook wrote: i want to keep it close to stock appearance from the outside. Then drop the motor. The 1600 MPFI can be fitted UNDER a 1L bonnet. So a 1.3L bonnet is easy! RUF should get you the room you need to leave the stock sump in place. Just move the motor down and back, shorten your jack shaft and enjoy a more stable rig. Low is where its at
hmmm mine might be fun then
I'm not far off putting the front clip back on but its 1.6 vit and 3pd auto with no body or spring lift on stock engine mounts.
would it be possible to lose 25mm of height out of the vit inlet manifold and rewelding?? anyone?
Fatzook
 Posted: Wed Mar 16, 2011 11:16 pm |
ajsr wrote: Fatzook wrote: lumpy_zook wrote: i want to keep it close to stock appearance from the outside. Then drop the motor. The 1600 MPFI can be fitted UNDER a 1L bonnet. So a 1.3L bonnet is easy! RUF should get you the room you need to leave the stock sump in place. Just move the motor down and back, shorten your jack shaft and enjoy a more stable rig. Low is where its at  hmmm mine might be fun then I'm not far off putting the front clip back on but its 1.6 vit and 3pd auto with no body or spring lift on stock engine mounts. would it be possible to lose 25mm of height out of the vit inlet manifold and rewelding?? anyone?
Probably not. BEst I have done is 15mm drop. Can you make new mounts? Or are you just being lazy
Are you opposed to welding to the rail? I am no longer using my custom 1.6 mounts. Might be persuaded to send them to you  Should be good for a 30mm+ drop
ajsr
 Posted: Thu Mar 17, 2011 6:54 am |
no major reasons, I just had a ben T kit I was using the mount etc, but Ill reweld if I have to. Its probably much easier your right
