It is currently Tue Sep 29, 2026 1:43 pm
Vehicle: stock yellow vit.
Post Posted: Tue Mar 22, 2011 7:57 am
hey guys the doors on my swb vitara have quite a bit of sag in them just wondering if you could get new bushings for the hinges or if any of you fellas had a way to fix it
cheers jesse
Post Posted: Tue Mar 22, 2011 8:36 am
Not closing properly ?
Loosen the screws to the hinges, on the pillar, lift door to set it at right hight, do not overly loosen, they still need to be firm, or the flop about.
Sometimes you need a really strong arm to set them at the right hight.
Post Posted: Tue Mar 22, 2011 8:46 am
Having 2 people helps. :helloo:
Post Posted: Tue Mar 22, 2011 8:50 am
bottle jack under the slightly ajar door will also do it, support door with bottle jack. loosen screws slightly jack door & then re tighten.
Post Posted: Tue Mar 22, 2011 8:59 am
Yep to both, I have also put a block under the door, and used my full weight combined with small jumps to move doors, its a case of "if at first you don't succeed, get a bigger hammer'
Post Posted: Wed Mar 23, 2011 8:19 am
its not that they shut fine just when theropen you can pick up the door and feel thwe play in them
Post Posted: Wed Mar 23, 2011 9:39 am
You can not buy bushes to my knowledge only hinges. make sure the body is not cracked where the hinges bolt on see it more and more now days.
Suzuki is my way of life.
Users browsing this forum: No registered users and 124 guests
