It is currently Mon Jul 27, 2026 11:12 pm
Post new topic Reply to topic  [ 104 posts ]  Go to page 1, 2, 3, 4  Next
Vehicle: 95 Sierra Soft top
Post Posted: Fri Mar 25, 2011 2:08 am
Hey guys
Ive got this really loud wineing noise coming from my 95 sierra, now it only really happens under load, so when I acclarate its bad, espacily when I put it in 5th gear
Now 2 mechanics have told me its my diff or transfer case, but it doesnt sound like its coming from the back its more under nithe me, and I have read that sierras gearboxs start to make wineing sounds,
So shat do you guys think
Keith
Vehicle: MY2019 Jimny
Post Posted: Fri Mar 25, 2011 2:21 am
Don't go driving with the missus.
Post Posted: Fri Mar 25, 2011 2:28 am
im tring to chase the same problem i just put a reco box in it thinking it was the gearbox but went for a drive the excact same noise so i i found out its the transfer
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Vehicle: 91 WT 1.6EFI
Post Posted: Fri Mar 25, 2011 2:47 am
I have the same problem. I have just been turning the music up but it has been getting louder over the past few months. Could it be caused by water/mud in the rear diff? or maybe diff oil needs to be changed? or ya something in the transfer might do it as well
Post Posted: Fri Mar 25, 2011 2:50 am
It is hard to say - You could drain all the fluids, and see if any has nice metallic shiny oil come out of it?
Post Posted: Fri Mar 25, 2011 2:52 am
Well my diffs oil has been changed and the trasfercase aswell but my gbox oil hasnt been changed since I sank her about 5 months ago, so there has to be water in there still
I dunno lol
Post Posted: Fri Mar 25, 2011 2:54 am
How do you drain the gearbox and refill it ?
Post Posted: Fri Mar 25, 2011 3:08 am
plug on bottom .. and to fill it theres a plug on the back
Post Posted: Fri Mar 25, 2011 3:44 am
I have this same problem
F#%ING [P] PLATER
 Profile YIM
Vehicle: Work van
Post Posted: Fri Mar 25, 2011 3:49 am
Transfer bearings? Mine did the same thing, new case bearings and alls well now
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Fri Mar 25, 2011 3:55 am
Ya I was going to suggest something with bearings, they usually make that kind of noise when they ware out. can someone tell us where the bearings are and how to get to them?
Post Posted: Fri Mar 25, 2011 3:56 am
PM Weaves for bearings.
Post Posted: Fri Mar 25, 2011 4:14 am
Whos weaves and does he have a online shop or anything ?
Vehicle: Work van
Post Posted: Fri Mar 25, 2011 4:17 am
Inside the transfer case :thefinger: 1 roller bearing on each end of the input shaft, 2 needle rollers in the counter shaft , 2 rollers and 3 needle rollers on the output shaft
Vehicle: Daisy
Post Posted: Fri Mar 25, 2011 4:18 am
My transfer whined pretty loud immediately after putting gears in it, you can hear that it's just the brand new gears meshing together.
It's heaps quieter now, in fact I'm about to go and do my first transfer case oil change since I put the gears in two weeks ago, it hasn't done the full 1000 miles (1600km) that they say to do, but they also say to change it after the first time offroad, which was two days after I put the gears in and I didn't go very hard so I figured it needed more time to wear in.
It's done probably 800 or so km since they went in, bloody good improvement it has made!
Post Posted: Fri Mar 25, 2011 4:21 am
Weaves is the official Auszookers Bearing Partner.
Post Posted: Fri Mar 25, 2011 4:23 am
hes on this forum, just did a search its $92 +14 freight for the full sierra transfer bearing kit. you can find him by searching his name .
not to change topic but Teracis have you noticed better fuel consumption since putting the gears in?
Vehicle: Daisy
Post Posted: Fri Mar 25, 2011 4:35 am
I thought I did for the first tank, I'm on 235's with 6.5 gears. Problem is, my zook is having issues which have gotten worse since so I haven't done a real world test yet.
Whether they improve fuel economy or not, they make the thing far FAR more driveable, it would not be nice to go back to stock gears now!
Post Posted: Fri Mar 25, 2011 4:45 am
true, I think I'll do my case then on a few months. by that time my clutch will be completely rooted and I can do them both.
ok, back to bearings
Post Posted: Fri Mar 25, 2011 5:16 am
does weaves kit include shims?
Post Posted: Fri Mar 25, 2011 5:21 am
Vehicle: Daisy
Post Posted: Fri Mar 25, 2011 5:43 am
Post Posted: Fri Mar 25, 2011 6:34 am
I work for a national bearing company and I can tell u now that u should definitely get ur bearings off Weaves. That's a DAMN good price for those bearings and seals. Good on ya Weaves :Smile:
Vehicle: 1985 Holden Drover
Post Posted: Fri Mar 25, 2011 6:43 am
Haha ive spent all arvo chasing the same issue, plus a leak on the rear seal on the transfer case doesnt help the cause, plus all the more reason to change em!
Another thing i wanted to check was the rear diff oil, except its like the plug is welded in! Tried every way we knew how without using a welder/grinder. With 2 fitters and a mechanic on it i think we might have to use the grinder :(
Weaves will be making some more cash soon! :P
1989 WT Sierra.
Post Posted: Fri Mar 25, 2011 7:43 am
Square drive with an extension bar didn't work?
Post Posted: Fri Mar 25, 2011 8:08 am
Nope just rounded the plug. I think its pretty happy where it is :P
1989 WT Sierra.
Post Posted: Fri Mar 25, 2011 8:15 am
haha oh no
Post Posted: Fri Mar 25, 2011 8:55 am
Atleast i know its not going to leak :roll:
1989 WT Sierra.
Post Posted: Fri Mar 25, 2011 8:59 am
Someone once said it's a 3/8 square drive, not 10mm
bye
Post Posted: Fri Mar 25, 2011 9:01 am
Yep tried both plus making my own once it started to round out. Looks like im welding a nut to it then :(
1989 WT Sierra.
Users browsing this forum: No registered users and 325 guests
