It is currently Mon Oct 12, 2026 11:48 am
Vehicle: G16b 83
Post Posted: Sat Apr 16, 2011 1:26 pm
ive been looking for hours does anyone have the pinout for a 96 baleno (with dizzy) its a 6k 1.6 e24 33920-60gm1 112000-3081 12v denso
Post Posted: Sat Apr 16, 2011 10:26 pm
try this and scroll down
http://www.redlinegti.com/forum/vt.19261.htm
Post Posted: Sat Apr 16, 2011 11:28 pm
None of those links work.
Vehicle: G16b 83
Post Posted: Sun Apr 17, 2011 10:37 am
Where is the tacho meant to be hooked up to
Post Posted: Sun Apr 17, 2011 1:44 pm
If you are looking for the tacho lead under the bonnet it is the solid brown wire found near your coil and distributor.
If you are looking for it under the dash I can't help, mine was plug and play in the interior.
Post Posted: Sun Apr 17, 2011 2:01 pm
you can open the ecu cover and written on the circuit board
should be a symbol tach next to one of the pins from memory.
im pretty sure thats the one i used for the signal or it might have been from the coil ? sorry its been quite a while since ive done it, the details are a bit fuzzy
Post Posted: Sun Apr 17, 2011 8:31 pm
There ya go Russ... Good luck....
Users browsing this forum: Google [Bot] and 218 guests
