It is currently Mon Jun 08, 2026 10:14 am
Post new topic Reply to topic  [ 166 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
lesspostingmorewheeling
Post Posted: Tue Aug 12, 2008 6:42 pm
wow i'd hate to think how much they would want for them down here then
does your sway bar still fit?
Post Posted: Tue Aug 12, 2008 6:44 pm
yep the sway bar still fits not problem. the diff is only about 20-25mm forward.
Post Posted: Tue Aug 12, 2008 6:51 pm
mine isn't close to fitting bit my diff would only be about 25mm or so forward too
Post Posted: Tue Aug 12, 2008 7:08 pm
why not? does it move in the bushes that are on the chassis bit. i had to give it a good pull and push to free these up then it bolted up.
how have you set up the springs? what have you drilled, shackel size?
Post Posted: Tue Aug 12, 2008 7:12 pm
cost me 60 for both... But u needed them , now u gottem!
Post Posted: Tue Aug 12, 2008 7:22 pm
60 is what i was expecting. didn't tell me a price till he had done them. if he had i would of went up the road and got some braided steel ones made up for $100.
Post Posted: Tue Aug 12, 2008 8:12 pm
i don't see nearly 100bucks in a couple bits of hose and some fittings
Post Posted: Wed Aug 13, 2008 7:22 am
thats what you pay around here for the braided stuff.
i think $100 is cheap to know your car will stop when you want it to.
Post Posted: Wed Aug 13, 2008 10:41 pm
i just worked out why the sway bars wouldn't work
i haven't made the shackles yet but they are gonna be around 2 to 3 inches longer than the standard ones so it should sit level
i haven't had to redrill anything it all seems to work
Post Posted: Thu Aug 14, 2008 7:03 pm
your streeing arm will hit on your steering link when the wheels are point strate and hit a bump, that is the only reason i redrilled the pads.
Post Posted: Thu Aug 14, 2008 8:08 pm
is this a bad think? or is it just annoying?
Post Posted: Thu Aug 14, 2008 8:14 pm
its very bad, exploding steering is not cool
Post Posted: Thu Aug 14, 2008 8:25 pm
the diff is only about an inch forward and the diff sits about 3 inches lower will that still be a problem?
Post Posted: Thu Aug 14, 2008 8:41 pm
if it can hit it can be a problem
better to make it so its not possible with stupid bumpstop spacers or moving the box or something
Post Posted: Thu Aug 14, 2008 9:26 pm
i think my best bet would be to put it all together then test to see where and if it hits because i can't really flex it in the garage
Post Posted: Fri Aug 15, 2008 11:10 am
yep it will hit. just get under the car and have a look, you can see where it will hit with out flexing it up.
Post Posted: Sun Aug 17, 2008 1:07 am
if you put ruf will that lift you front much
hello
Post Posted: Sat Oct 04, 2008 10:12 pm
Did a mini RUF during the week using suzuki carry rear springs. They are approx 50mm longer than 2" lifted sierra front springs, and the centre-pin is approx 45mm forward of stock.
I used main carry leaf, 3rd and 4th leaves out of my 2" lifted pack and the 3rd carry leaf. No load leaves. I might add an extra leaf on the drivers side to try to counter the sierra lean :?
To fit them I redrilled the rear spring mount 20mm back and 6mm up. This puts the axle approx 25mm forward. The steering arms clear by 5-10mm so no trouble there.
I used 40mm extended shackles. This gives a nice shackle angle.
It probably gave 1-1.5" of lift (so dropped a little from the previous 2" springs).
Flex is awesome to say the least. Quite a big improvement from before. I have 1" bumpstop spacers to help fit the longer shocks and stop the tyres rubbing on the guards (which still needed a fair bit of massaging with a hammer)
Shocks aren't fitted in this pic as I was measuring to make sure they were still long enough, which they were
2" extended brake-lines are plenty long enough
So overall Im very happy with my $30 carry springs. The ride is softer than before, quite comfy, flex is better. Cant go wrong :lol:
Member of C.O.R 4x4
Post Posted: Sun Oct 05, 2008 12:32 am
that shackle angle is a little backwards
Post Posted: Sun Oct 05, 2008 1:54 pm
What do you mean backwards :?
Member of C.O.R 4x4
Post Posted: Sun Oct 05, 2008 2:34 pm
looks pretty good to me
good work.
Post Posted: Sun Oct 05, 2008 3:12 pm
Looks perfect to me, nice job.
92 WT softback ute, twin lockrights, 3.9 diffs, S1
Vehicle: LJ20 LJ50
Post Posted: Sun Oct 05, 2008 9:22 pm
nice idea and cheap (the way we all like them :-)
Camels have nice toes
Post Posted: Mon Oct 06, 2008 1:57 am
i dont know what i was talking but the flex is great. any reason as to y u didnt use sierra rears?
Post Posted: Mon Oct 06, 2008 2:38 am
They were cheap, $15 each. Carry springs put the axle in a good position (1" forward of stock) without having to re-drill the spring perches.
Also sierra rears are another 2" longer (4" longer than fronts) so I would have to either redrill rear mount further backward (dont really want to as theres not alot of metal there) use longer shackles (again dont really want to) or do a chassis extension (too much fabrication for me).
Sure sierra rears may give a little bit more flex, but im not sure it'd be worth the extra hassle when the carry springs give some decent flex and are so simple and cheap to install.
Member of C.O.R 4x4
Post Posted: Mon Oct 06, 2008 11:46 am
looks spot on to me
Post Posted: Wed Oct 08, 2008 11:27 pm
The shackle angle is not the best mate. It should be a little closer to verticle. About 35-40 deg from verticle is ideal. Yours is more like 60 deg from vert. You run the risk of inverting the shackles on compression.
If you can move the front hanger forward it will give you a little more lift aswell as correct your shackle angle. 40-50mm should do it.
Otherwise, nice job :) You can't knock $15!!! :D
Pete
Post Posted: Thu Oct 30, 2008 12:05 am
what has more flex in the springs
ruf or 2inch lifed springs
and if i do a ruf do i have to buy some 2 inch lifed springs for the rear
Post Posted: Thu Oct 30, 2008 12:07 am
ruf has more flex
yes you need 2inch rears
Post Posted: Thu Oct 30, 2008 12:47 am
Std Rear up front with 2" lifted rear springs in rear
Users browsing this forum: Google [Bot] and 54 guests
