It is currently Mon Jun 08, 2026 12:49 am
Post Posted: Sat Apr 23, 2011 1:42 pm
After some advice from the auszookers oracle,
Today I cracked open a front diff ive recently bought out of a comp car, and found 1 tooth on the ring gear is chipped. I cant find the chipped piece in the housing, pinion seems to be in good condition, all feels good.
How do ya reckon it will hold up? is it likely to chew out the pinion, and in turn, the ring gear?
Go Hard, Trailer Home
Vehicle: SJ50 hardtop!
Post Posted: Sat Apr 23, 2011 7:45 pm
Throw it out before it explodes and fucks more up
NT SJ50
Post Posted: Sat Apr 23, 2011 7:48 pm
:wink:
Post Posted: Sat Apr 23, 2011 8:02 pm
for the risk of potentialy busting and taking out your locker i wouldnt risk it...
altho if it was an open center i recon if you were an easy driver it would last.
ps Rusho. saw your car yesterday at glasshouse, very neat, good job
Post Posted: Sat Apr 23, 2011 8:39 pm
Thanks Mr.Evl :wink: Was that you on the Moto's?? Looked familiar but couldn't put a name to the face :oops:
Post Posted: Sat Apr 23, 2011 8:52 pm
I'm currently having my locker fixed from a busted axle and pinion and it's costing me $1000. You don't want to go there!
X3, bin it!
If your not breaking shit, try harder!!!
Post Posted: Sat Apr 23, 2011 9:01 pm
Ask Royce....... :helloo:
Post Posted: Sat Apr 23, 2011 9:30 pm
Is this a trick question? Nah, bin it, put the locker in a good diff.
Vehicle: Daisy
Post Posted: Sat Apr 23, 2011 9:49 pm
Surely shouldn't be that hard to change only the ring gear? Just get another one!
Post Posted: Sat Apr 23, 2011 10:00 pm
Problem is they're a pair (crownwheel and pinion). Pinion height is the hard part in diff setup, but you could replace both. If you change the crownwheel only it's likely to get pretty musical. Cheap and easiest to put the locker in another centre.
Post Posted: Sat Apr 23, 2011 11:41 pm
Thanks lads, was pretty much what I was expecting. It is a vitata front steel housing, so swapping it to another diff ain't gonna happen :wink:
Post Posted: Sun Apr 24, 2011 12:17 am
what ratio do you need to replace it. while you have it out its easy to swap the ring and pinion gears over.
Post Posted: Sun Apr 24, 2011 1:48 am
If you have another crownwheel you could get them lapped!
Post Posted: Sun Apr 24, 2011 2:47 am
What does that mean? :?
Vehicle: 2018 DMAX
Post Posted: Sun Apr 24, 2011 3:25 am
Lapping Process
Goodwill Engineering
To ensure smooth and quiet noise free functioning, the Gears and Pinions are lapped after hardening. Lapping is accomplished by running mating pairs together in a Gleason Hypoid lapping machine and then feeding a liquid abrasive compound under pressure into the gear pair. The compound removes small amounts of metal as the gears rotate, thus refining the tooth surface and achieving desired contact pattern.
Post Posted: Sun Apr 24, 2011 3:27 am
boostedbrick wrote:
Lapping Process
Sounds pricey 8O
Post Posted: Sun Apr 24, 2011 9:43 am
Joe wrote:
boostedbrick wrote:
Lapping Process
Sounds pricey 8O
cheaper than a missing tooth or miss matched gear's...
Post Posted: Sun Apr 24, 2011 10:12 am
I'll be able to tell you at the end of the week when I get the itemised bill as lapping will be part of my rebuild.
Post Posted: Wed Apr 27, 2011 2:15 pm
I had hotline 40 autoparts send me a sms the other day looking for a 5.12 front, I pushed past the collection of rear diffs & GV steel housings... and found nothing, well I found a couple but not sure what they are. I know one is a 4.6 & the other one I will have to check.
Post Posted: Wed Apr 27, 2011 2:51 pm
its a crown wheel not a ring gear, ring gear is loctaed on your flywheel, get rid of it replace it with the same ratio that is in the other diff, i thort these gear sets were cheep enuf new
Post Posted: Wed Apr 27, 2011 2:55 pm
R&P = ring & pinion & they're both gears, so ring gear works for me... it is also a crown wheel & pinion... you say tomato, i say tomato. :wink: i'd hate to price a new one from suzuki, but they do come up forsale 2nd hand quite often.
Post Posted: Wed Apr 27, 2011 10:09 pm
Something about that break makes me think that diff wasn't set up properly. It looks like the contact patch was WAY out.
Sierra or vitara R&P's aren't hard to find unless they are 4.8 or 4.3. 5.12's are everywhere. Just replace both R&P
Post Posted: Thu Apr 28, 2011 11:26 am
Cant tell you the price as the bill is itemised, but it only has a total price.
Users browsing this forum: No registered users and 14 guests
