It is currently Wed Jul 29, 2026 9:57 pm
Post Posted: Tue May 17, 2011 7:56 am
I recently got a a/c unit from a 94 sierra :D the a/c pulley obviously has a 2nd smaller pulley attached for the belt.. This pulley has 5 holes to attach to the crankshaft... my 1.3 sierra pulley only has 4 holes??
question. did they make 1.3 sierra A/C pulleys with 4 holes?? or do they all have 5??
Do I drill out other holes into the A/C 5 hole pulley to suit the engine I have??
Post Posted: Tue May 17, 2011 7:57 am
5 hole pulley is Vitara...
Post Posted: Tue May 17, 2011 8:17 am
tru.... can it be drilled out to suit sierra?? or is that alittle to dodgy??
Post Posted: Tue May 17, 2011 9:17 am
My G13A has a 5 bolt pulley - noticed that the pulley is a double row V as well. Is this normal? I don't have a pic of the pully at the moment but u can see on the timing gear that it has 5 holes.
Post Posted: Tue May 17, 2011 9:34 am
thanks heaps for that pic Jasen :D
I'm not going :crazy: then
Post Posted: Tue May 17, 2011 10:09 am
if you can get hold of a timing gear with 5 holes in it i would think it would solve your problem!(as long as they are the same size!)
PS. I'll come help work on your car on the weekend if you want.
If you don't get stuck you aint tryin' hard enough
Post Posted: Tue May 17, 2011 10:12 am
I'll be here :D got heaps to do and I don't have exams :D yaye.. I think there is one on the old 1600 vitara block down the shed.. not sure.. Think I have one stashed somewhere also... will load up pics of the different pulleys
Post Posted: Tue May 17, 2011 10:18 am
Be careful using a 1.6 timing belt pulley on the crank...
I can't remember off the top of my head which is which (1.3 or 1.6) but one runs a round tooth belt and one runs a square tooth belt....
Post Posted: Tue May 17, 2011 10:21 am
pics of the pulleys
Post Posted: Tue May 17, 2011 10:22 am
thanks for that.. will check
Vehicle: Daisy
Post Posted: Tue May 17, 2011 10:27 am
I know my mrs brother's 1.3 has a crank pulley which is double (like the one on the right) I'd have to check whether it has 4 or 5 bolts though but it's a stock 94 1.3l if that helps.
Post Posted: Tue May 17, 2011 10:29 am
G13A is 4 bolt, G13BA is 5 bolt, G15 is 5
and yes there are 2 different timing belt profiles, hopefully one isnt G13A and one G13b :)
Post Posted: Tue May 17, 2011 10:39 am
found the old flogged out timing gear from a 1.6.. found it in my lunch box :D It has square teeth.. also noticed the vitara pulley has a ribbed belt and the sierra has teeth..
Post Posted: Tue May 17, 2011 10:53 am
my engine would be a G13A 4bolt..
any ideas if U can get a 4 bolt A/C pulley ???
or would I need to get a new timing gear to suit G13BA 5bolt ??
Vehicle: '94 suzuki maruti
Post Posted: Tue May 17, 2011 12:15 pm
don't '94 sierra's have the G13BA?
Edit: misread your first post as you having a '94 sierra, nevermind :oops:
Post Posted: Wed May 18, 2011 1:02 am
Ah my engine might be a bit of a frankenstein then. It's a 94 sierra but the engine has been replaced with a g13a some time before i bought it (1324cc cast on block). I'm assuming they just replaced the block and kept the g13ba crank etc.
Post Posted: Wed May 18, 2011 1:16 am
no you didn't misread, he has a 1L sierra with a 1.3L engine in it (unknown year, probably an earlier one). he just brought the aircon from a 94 sierra for his car.
Post Posted: Wed May 18, 2011 3:36 pm
I have re-drilled several 4 bolts to 5 bolt, with no dramas. I did make sure they were properly lined up and centered though.
I spent $75 or so on a double row pulley (one ribbed, one v-belt), and couldn't see letting it sit on the shelf, so I re-drilled it. I have done some for friend since, and they have had no dramas either.
Users browsing this forum: No registered users and 365 guests
