It is currently Tue Sep 29, 2026 12:37 am
Post Posted: Mon Sep 08, 2008 7:13 pm
i have an few problems with my transfer case . the question is , i have an nother transfer case that has the handbrake drum on the back of it but my car has the handbrake on the rear drums will the transfer case be an simple bolt up ( and take the handbrake stuff off it ) or it is compleatly diffreent
Vehicle: 75 Cruiser
Post Posted: Mon Sep 08, 2008 7:21 pm
itll bolt straight on and you can leave your handbrake drum on the back of the case.
BUT
the bolt pattern is narrow track on the handbrake case.
So, if you can swap all the drive shaft flanges from the wide track case to the NT case you'll be right.
Post Posted: Mon Sep 08, 2008 7:49 pm
so if i take the handbrake stuff off i wont have to swap any think over
note i have the handbrake on the rear drum brakes ( on the diff)
Vehicle: 75 Cruiser
Post Posted: Mon Sep 08, 2008 7:59 pm
you'll want to change the flanges on your transfer case to suit your drive shafts, you'll want to change all three flanges, two driveshafts to the diffs and one to the gearbox, so yeah you'll have to remove the handbrake drum.
I have a NT case in my WT but i just swap driveshaft ends to match the NT case flanges.
Post Posted: Mon Sep 08, 2008 8:02 pm
ok thx for that
i will have na go at swating it over during the week
Users browsing this forum: Google [Bot] and 152 guests
