It is currently Sat Oct 24, 2026 4:03 pm
Post Posted: Wed Jun 22, 2011 7:06 am
For those who bought a kid from the states, with just mounting brackets. Quite sure for both vits and sierras.
What have people done to stop water getting into your rear bearings through the gap left by the caliper bracket?
Just not wanting to get water and dirt in areas that shouldnt get water and dirt in them.
I know the benT kit comes with a metal insert. Guess i can make one up myself one but woundering if anyone else has come up with a quicker and better solution..?
cheers.
pictured here:
Post Posted: Wed Jun 22, 2011 7:08 am
Wheel bearing's sealed...... :helloo:
Post Posted: Wed Jun 22, 2011 7:12 am
so they are water tight?
Post Posted: Wed Jun 22, 2011 7:14 am
Nothing is mate......
Vehicle: LWB Sierra & XL7
Post Posted: Wed Jun 22, 2011 7:32 am
As you know, BenT's kit addresses this with a spacer.
You would just have to use Gasket sealant, do a BIG bead that will cover the gap. You'd need to use sealant on the recessed face anyways.
I use grey gasket sealant.
Post Posted: Wed Jun 22, 2011 8:01 am
I didn't get a spacer with the ben-t kit :?
Post Posted: Wed Jun 22, 2011 8:05 am
It's the yellowish half moon things that you've probably left out.
At first I was like, wtf are these for, after mocking it all up I soon realised what they were for.
That's fine, but what about the big hole in the center????
Post Posted: Wed Jun 22, 2011 8:10 am
The big hole of the brake rotor adapter? That butts up against the stub of the axle.
The big hole of the caliper bracket, The recessed part sits in the end of the diff. With my Vit it has that backing plate that holds on the drum brake shield thing. I put a bit of sealant around it and it sits flat against the brake caliper mounting points.
Post Posted: Wed Jun 22, 2011 8:12 am
That's the brake line bracket?
That has nothing to do with sealing it
Post Posted: Wed Jun 22, 2011 8:14 am
Sorry was ment to mention this was for a Sierra
There's no sealing of the bearing at all
Post Posted: Wed Jun 22, 2011 8:15 am
Still a hole mate.... the axel still need's tobe able to turn, so unless you fit an additional seal (then you have to lubricate it ) shit will still get to the bearing..
That's why the bearing's are sealed, even the std drum's let shit in top the bearing....
Post Posted: Wed Jun 22, 2011 8:19 am
correct
and tring to seal it all up will just make it worse and collect more water and mud, as once its there it cant escape again
Post Posted: Wed Jun 22, 2011 8:39 am
Ahh yep, now I got what you mean.
Anyways, here's a tech thread on how to install the rear disc conversion on a Sierra.
http://www.auszookers.com/index.php?nam ... conversion
'92 Vitara & Camper trailer
Post Posted: Wed Jun 22, 2011 8:45 am
One of the reasons I don't like rear disc conversions for semifloat axles.
I've seen a few of these conversions (done various ways) and they seem to chew bearings and axleseals.
Post Posted: Wed Jun 22, 2011 8:52 am
Mines already done
I don't like that the axel supports all the weight of the car
Don't mind changing bearing either
It's much easier to pull the axels out with rear disk then stock drum setup now
Will deffently go full floater down the track.
Post Posted: Wed Jun 22, 2011 8:54 am
zooky08 wrote:
Mines already done
care to explain???? :?
Post Posted: Wed Jun 22, 2011 8:55 am
The axleshaft supports the weight of the car in semifloating axle. Zooky08 was comparing semifloat with a full float axle.
Post Posted: Wed Jun 22, 2011 8:57 am
:roll: I'll lean to read one day......
Just add it to my many fault's......
Post Posted: Wed Jun 22, 2011 9:21 am
So, in a nut shell.
Recommended to keep it open to let crap out, but expect to have to change axle seals and bearings more freaquently than usual.
cheers for the help.
Users browsing this forum: Google [Bot] and 81 guests
