It is currently Fri Oct 09, 2026 12:16 am
Post Posted: Tue Jun 28, 2011 9:20 am
Hi all,
I have a 96 coily sierra.
While driving tonight i heard a grinding noise, i think it was comming from the rear end. It wasnt constant, it was like on off like a ticking if you can sorta understand and every now and then would squeal, when i got home it smelt quite a bit also. i know i havent given much info and i havent looked yet as its too dark, but any tips as where to start look or anything would be greatly appriciated.
Post Posted: Tue Jun 28, 2011 9:23 am
wheel bearing, siezed brake?
Post Posted: Tue Jun 28, 2011 9:35 am
I was going to say uni, but they don't smell :roll:
Post Posted: Tue Jun 28, 2011 9:37 am
Noises and smells from the rear end huh...?
Stop running the Sierra on beans, petrol works better ;)
I want my old sig back :(
Post Posted: Tue Jun 28, 2011 9:40 am
:lol:
:lol:
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Tue Jun 28, 2011 9:41 am
haha no beans, im sorta new to this stuff but i was thinking diff, tail shaft wheel bearing? am i on the right track?
SJ80 Coily 2 inch body+40mm lift+31 inch M/T=:D
Post Posted: Tue Jun 28, 2011 9:45 am
Absolutely :wink:
Post Posted: Tue Jun 28, 2011 9:47 am
Just hope i can get it fixed before the weekend, got a trip planned!!! will post if i run into any more troubles.
thanks for your help.
Post Posted: Tue Jun 28, 2011 10:11 am
diff and tailshaft wouldnt normally smell though... wheel bearings generate heat and burn their seals etc, a siezed on brake just smells bad =)
easy enough to test by jacking up each rear wheel and giving it a spin and feeling for play.
Vehicle: '96 LWB trayback
Post Posted: Tue Jun 28, 2011 10:13 am
Drive it and touch the hubs lightly. You'll soon feel the heat of a sticky wheel bearing or brakes.
Post Posted: Tue Jun 28, 2011 11:25 am
I jus had that problem pulled out the rear wheel bearings an half the balls had flat spots so changed em all good now
built not bought
Vehicle: Clown Car..
Post Posted: Tue Jun 28, 2011 12:26 pm
worn pinion bearing will smell as the oil seeps out n is flung round onto exhaust etc.. will also sound like a tick n squeal depending how bad it is..
Post Posted: Tue Jun 28, 2011 10:27 pm
I would be thinking brakes. If a rear cylnder is seized or sticking.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Users browsing this forum: No registered users and 164 guests
