It is currently Thu Oct 01, 2026 10:19 am
Post Posted: Mon Jul 11, 2011 1:30 am
Hi I have a 91 lwb vit with ds battery mount
I need to find the most powerful battery that will fit in the STD tray
It has a ameron battery in it now but it has died
Not bad as it is over 7 years old
Was thinking of getting the same one but wanted to know what other batteries people are running
Ps it has to be sealed I will never run wet cell batteries again
Vehicle: 92 Suzuki Sierra
Post Posted: Mon Jul 11, 2011 2:44 am
just food for thought, it doesn't take much to kick over a vit motor. Rather than getting a single big one get two smal ones and run them in parrallel. If one dies you still got the other
I am considering fabbing 3 12v 20aH sealed batteries in parralel. just trying to find a 3rd one cheap (got two for free at the tip which have been holding charge for the last 2 years)
-Santos
Post Posted: Mon Jul 11, 2011 3:45 am
It's the 12000 pound winch that can draw 400 amps that's the problem
I also have to get a new 40 amp deepcycle for the pass side
The stupid air intake is in such a stupid spot
If it ran straight instead of having the bends in it u could fit a heaps bigger batt in there
Post Posted: Mon Jul 11, 2011 4:04 am
Just get a good optima
They fit in the standard tray if you get the right one.
Google there website or ask Dank
Post Posted: Mon Jul 11, 2011 4:53 am
There is a solution to that :helloo:
I run a Amaron Calcium battery, its great.
Stocker
Post Posted: Mon Jul 11, 2011 7:23 am
http://www.batteriesdirect.com.au/shop/ ... ecial.html
Batteries Direct have a special on at the moment. Just picked up an Optima Blue top 34M for $275 delivered. Been using the same battery in my SWB with a 12000lb winch for 2 1/2 years no worries. Fits staight in with no mods so should do the same for a Vit. :wink:
SS
Post Posted: Mon Jul 11, 2011 9:42 am
OR Rerout the intake yess!!
-Santos
Post Posted: Mon Jul 11, 2011 9:51 am
hahaha, thanks captain obvious
Stocker
Post Posted: Mon Jul 11, 2011 10:50 am
I fit a mf75d23l in my sierra using the standard battery tray. Should be able to fit one in a vit without any dramas
Post Posted: Mon Jul 11, 2011 12:14 pm
I managed to squeeze In a n70zz in my lwb vit engine bay...just
710cca Armsup
Go Hard, Trailer Home
Post Posted: Thu Aug 04, 2011 11:25 pm
Post dig, But are those optimas the beez kneez? Would the standard altenator be able to supply enough power to the battery whilst using something like a 9000pound winch with the head lights on?
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Fri Aug 05, 2011 3:27 am
I had a Optima Yellow Top D34 in my magna with a 1.5kW sound system and it coped no worries.
I am in the process of installing a D51 into the Vitara and upgrading the cabling. For a small battery it packs a lot of punch... 41Ah, 500A CCA, 625A MCA
Post Posted: Fri Aug 05, 2011 3:45 am
The specs on the blue top 34M look alright.
Post Posted: Fri Aug 05, 2011 6:31 am
I ended up getting to odyssey extreams as I got them real cheap
I now have 1140 cca out of the 2 small batteries so that should be more then enough
Looking at the measurements on the optima spec sheet I didn't think they would fit in the tray
Users browsing this forum: No registered users and 111 guests
