It is currently Sun Aug 02, 2026 9:57 am
Post Posted: Tue Aug 09, 2011 9:18 am
anyone got any ideas.my rear brake drums wont come off. i have disconnected handbrake cable and still stuck? :(
Post Posted: Tue Aug 09, 2011 9:44 am
Use a big fu&@ off hammer, worked for me,
Nahh I'd bolt Ur wheel to the drum make sure The 4 nuts holding the drum on are undone and giv it an almighty wiggle , shuv, prod, push and a kick , might work ?? :blink: ?? Worth a try
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Tue Aug 09, 2011 9:48 am
There is a a brake adjustment on the back of the drum. Its basically a thread that adjusts the brake. You need to stick a small flat bladed screw driver into the hole feel around a bit. If you can wait till tomorrow i will get some pics up tomorrow morning showing what i mean. Kinda hard to explain, easier to show with pics :D Maybe someone else might be able to articulate it better then me but meh, whatever :D
Dave
Post Posted: Tue Aug 09, 2011 10:14 am
Or a slide hammer. Attach it to one of the studs with a wheel nut and belt the shit out of it :D :D :D (it may bend something, i have bent the brake pad metal bit doing this once, just a word of warning!!)
Post Posted: Tue Aug 09, 2011 10:25 am
if the four nuts in the middle are definitely off. and the brakes are not on.
Hit a hammer with some decent blows around the circumfrence of the drum it should wiggle off.
Post Posted: Tue Aug 09, 2011 11:21 am
Either a hammer as others have suggested, or keep dumping the clutch in first and reverse until it releases heh.
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Tue Aug 09, 2011 11:40 am
wind the wheel nuts out so there is only a few threads left and use the wheel as a slide hammer
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Post Posted: Tue Aug 09, 2011 11:43 am
dont think he wants to take the axle out aswell
Post Posted: Tue Aug 09, 2011 11:46 am
different nuts. undo the four axle nuts and leave the wheel nuts on a bit.
Post Posted: Wed Aug 10, 2011 6:48 am
big hammer did the trick.thanx guys :D
Users browsing this forum: Google [Bot] and 65 guests
