It is currently Thu Oct 15, 2026 8:37 pm
Post Posted: Mon Aug 29, 2011 3:47 am
:helloo:
does anyone have the part numbers for all the bearings and seals for a LJ80 4-speed gearbox?
thanks.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Mon Aug 29, 2011 5:03 am
Are you after the Suzuki part numbers or the Bearing / seal number?
Post Posted: Mon Aug 29, 2011 5:28 am
just the bearing/seal numbers please :)
79' LJ80 (sold) :(
Post Posted: Mon Aug 29, 2011 5:42 am
Suzuki part number and their sizes/bearing numbers. 99% sure that this is correct. :)
09283-20028 Front oil seal 20x47x8.5
24780-79001 Rear oil seal 28x38x10x15
08113-62040 Bearings (you need 2) 6204C3
08163-62040 Bearing 20x47x14
08163-63040 Bearing 6304NC3
09263-17014 Needle Roller 17.5x22x15.8
Post Posted: Mon Aug 29, 2011 5:43 am
awesome. Thanks Fity :D
79' LJ80 (sold) :(
Post Posted: Mon Aug 29, 2011 6:24 am
I am not 100% sure if a LJ80-I and LJ80-II (Stockman) are the same, however I think they are both the same as a LJ50.
Post Posted: Mon Aug 29, 2011 7:25 am
dont know if this is of any help,
but when my lj80 box dropped a heap of teeth, I just replaced everything with the cogs, seals and bearings from the spare lj50 box.
only difference was the bell housing being made for different bolt pattern motors.
internally they were identical.
stephen
Post Posted: Mon Aug 29, 2011 1:16 pm
LJ's get their awesomeness from the 4th dimension, Sierras just have a good spin circle ratio. :helloo:
Post Posted: Mon Aug 29, 2011 2:25 pm
The only difference I've noticed between early and later LJ80 boxes is the later ones have a different aluminium casting for the shifter on top of the box. Seems the Stockman's scored some sort of the "sticky up bit" (yes thats a legit term) that the 80's and 50's dont have.
:lol: :lol: :lol:
The 4th dimension is apparantly time...... so could be estimated life span of the seal?
Clearance Hole Technology :P
Post Posted: Tue Aug 30, 2011 1:58 am
Looking at the seal it is 10mm wide at the mounting face and 15mm total width.
Post Posted: Tue Aug 30, 2011 1:29 pm
Try as you may to spoil it with facts, LJs are still full of awesomeness.
Users browsing this forum: No registered users and 367 guests
