It is currently Mon Jun 22, 2026 10:44 pm
Post Posted: Tue Sep 13, 2011 6:17 am
im trying to get my reverse lights to work but they seem not to work,
all fuses and bulbs are fine, so i pulled the switch of the box to see if it was the switch.
is there ment to be some kind of plastic push rod thats in the end of the switch? mine dont seem to have one, if there was ment to be one in it
also if i go to push some thing down the hole it start smoking. not sure if i should of done that :roll: :cry:
Post Posted: Tue Sep 13, 2011 6:57 am
There should be some form of a pushrod in it...
It looks like it onky has one wire coming out of it? It should have 2.
Post Posted: Tue Sep 13, 2011 7:18 am
That's what I thought. It does have two wires, just that one is hidden under the other.
Any way was faulty switch. I swapped it over with a Sierra one nd now I ghave reverse lights :D
Post Posted: Tue Sep 13, 2011 7:21 am
:helloo: bingo....
Post Posted: Tue Sep 13, 2011 7:40 am
I've change the plug on the Sierra one so it can plug into the jimny plug but now lights are staying on?
No wires are touching each other
Post Posted: Tue Sep 13, 2011 8:15 am
Spray WD40 up the guts of the Jimny one, test it with a Multimeter. sometimes they just get gunked up
Stocker
Post Posted: Tue Sep 13, 2011 8:19 am
that could work, but i dont have no push rod to go in it, there was none when i pulled it out.
also it started smoking and sparking when i tryied to push some thing down the hole.
Post Posted: Tue Sep 13, 2011 9:31 am
Post Posted: Tue Sep 13, 2011 9:42 am
that surely was my reaction.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 92 guests
