It is currently Fri Jul 03, 2026 6:59 am
Post Posted: Thu Sep 29, 2011 8:20 am
ok well iv got some hilux diffs sitting at home and the plan was at first to
link it up etc but due the the fact mainly money wise iv decided to extend the chassis and run spring under on hilux diff to run low COG also to keep the whole thing alot more simple .. now i do remember telling me that hilux diffs are not easy for setting up Spring under can someone explane to me why is it because of the steering set up ?
also im still planing on running a 105 WB and 25 inch belly and 37s i did have a link to someone's build on Zuki kralwers with the chassis cut and he basicly did what simon did to his made it a LWB and linked it but im not going to link it so i need to work out how long the chassis needs to be extended
Post Posted: Thu Sep 29, 2011 8:45 am
It's partially steering, it's partially because of the size of the diff pumpkin wanting to get into the sump and chassis.
There was a guy on Pirate trying this, but I think the thread died (?)
Post Posted: Thu Sep 29, 2011 8:49 am
Ah thanks Steve well il just do Spring over with the lux diffs also need to figger out what springs to run i was thinking Hilux springs ? what do u think Steve
Post Posted: Thu Sep 29, 2011 8:51 am
Yes, you need a high rate with minimal arch. There's no need to run 50mm wide springs with the weight of the hilux diffs - you'll just screw them up.
Post Posted: Thu Sep 29, 2011 9:06 am
i would imagine a track bar would be a must as well?
Post Posted: Thu Sep 29, 2011 9:09 am
25" belly spua??
Post Posted: Thu Sep 29, 2011 12:14 pm
appsie wrote:
25" belly spua??
i dono its a rouge idea atm i was going to run a different set up but as i said im going to opt for the more simple budget set up i guess il play it by ear get the new Perches on the diffs find some springs etc a ..track bar is a must i think
Post Posted: Thu Sep 29, 2011 12:30 pm
what about a shaved top on the diff??
Post Posted: Thu Sep 29, 2011 1:02 pm
There is a SPUA hilux diff zook with 35"(ish) boggers in newcastle,
Post Posted: Thu Sep 29, 2011 1:08 pm
Im Sure it can be Done i just just the Placement of the Diffs them self and a Shaved top wouldnt be bad idea
Post Posted: Thu Sep 29, 2011 1:17 pm
I don't think you would gain any tangable clearance from shaving the top.
And I'm sure SPUA lux diffs can be done.
Post Posted: Thu Sep 29, 2011 1:24 pm
yer il just run Spring over :)
Post Posted: Thu Sep 29, 2011 1:29 pm
would be a major pain in the ass, but you could shift the engine position to make sure the sump cleared.
still, why are you opting for leaves? if you're going to the effort of low COG and lux diffs, why not build a decent coil sprung setup? that way its technically SPOA still, but you can fine tune it a fair bit more.
Post Posted: Thu Sep 29, 2011 1:40 pm
hey Alien you do have a point but i think low COG will be quite hard to get running springs the reason is mainly money i realied that its going to cost me quite a bit to set it up the way i want to i dont think it will be easy or Cheap
what i was thinking is i can always change the set up later when i have money right now i just want my zook back up and running so i can go hammer it around now im not saying its real easy to set it up right but i figger its cheaper i can get the springs for free il extend the chassis where need be and run it around im thinking something like this Image its got 106 WB and 39s
http://www1.pirate4x4.com/forum/showthr ... 788&page=3
Post Posted: Thu Sep 29, 2011 2:46 pm
From that pic, looks like a spoa with a quirky front setup.
Alot of sierra's with 35's, the top of the tyre is inline with the top of the chassis front and back. Unsure what belly you get then, but its an idea of what people are running.
You won't want bodylift on top of that. It will just look too massive. :lol:
Post Posted: Thu Sep 29, 2011 10:42 pm
question: where do you plan on driving something that big? lol you'll have to travel a fair distance to get anything thats a challenge for it.
IMO drop the tyre size to 33x10.5 and use the money saved on those to do a coil setup on WT diffs... build something that can do a little fast as well as crawl and i reckon you'll have more fun driving it.
Post Posted: Fri Sep 30, 2011 1:13 am
O Dont Worry il Find Stupid Challenging things to do with it :lol:Also dont forget il comp It .. i hope so should be a bit of a challenge there i was going to build something like Edges Zook but i think its going to cost far to much for my liking as i said before I will be done haha :)
Post Posted: Fri Sep 30, 2011 1:15 am
haha a body lift on top of that would be stupid yes haha yer i know what your meaning about the Tyre in-line with Top of Chassis I Might Go have a Chat to Tuls today :) Steel some ideas haha
Post Posted: Fri Sep 30, 2011 1:46 am
tuls is built pretty much the same as mine - SPOA on lux fronts... but he runs drop shackles as well as a bodylift.
Post Posted: Fri Sep 30, 2011 1:59 am
i know :) Tuls its a Bit Tall for my Liking if it had a longer WB it would be so bad i still want to aim for 105 WB On the 37s I just Need to Work out what Springs Will Suit Best for the Job I might Frankenstein some springs Mix match etc Some long Springs Like in that photo would be great i messaged the guy about the green zook hopefully i can get some more info later :)
http://www.pirate4x4.com/forum/showthre ... weld+build
Post Posted: Fri Sep 30, 2011 7:00 am
what sort of comps are you going to be running in? you need to figure that out and build to a class.
Post Posted: Fri Sep 30, 2011 9:27 am
X2 - there's been plenty of unfinished projects sold for nothing over the years because they didn't fit the class rules of whatever short lived series it was they were being build for.
However, a comp only car is a waste of time and effort in my opinion. Driving comps and private property just doesn't allow enough seat time or variety. JMHO.
In fact, I reckon the only off road competition that offers enough seat time is off road racing. Same $$$ as 4WD comps but miles more seat time per year.
Post Posted: Sun Oct 02, 2011 12:01 am
Rego'd vehicle comps are good for that.
Drive to the comp, compete, drive home, drive to work, wheel on the weekend etc
Post Posted: Wed Feb 27, 2013 8:19 pm
Bump in the hope that there might be a bit of info out there
Post Posted: Wed Feb 27, 2013 8:22 pm
There is a guy down here with shortend lux diffs under a maruti. i am led to believe it was original SUA
Users browsing this forum: Google [Bot] and 171 guests
