It is currently Sun Aug 02, 2026 2:26 am
Post Posted: Fri Sep 30, 2011 1:32 am
well as u know i picked up small little suzuki for my daylie it has 1.3 block and 1.6 head
was going great when i first got it lots of power after a few times off road it starting coughing spluttering i changed the fuel filter and it started going good then it went bad again so i thought it was dirty fuel droped tank filtered all the
fuel and its basicly the same as it was when you put your foot down there just seems to be a lack of power now untill revs get up .. when i first got it i could drop Rubber easy .. now after looking at the whole fuel system i think it could be carby maby dirty any ideas what i should look at after i take the carby off .. i also think it could be the electronic fuel pump messing up its quite nosy now any as it was not mounted properly and was just hanging getting whacked around when i first got it .. any way to test the pump any ideas thanks guys :)
Vehicle: Yellow Ute
Post Posted: Fri Sep 30, 2011 1:38 am
Take the jets out, give em a clean (Scratch around inside with a needle of blow through with a compressor). Get some carby cleaner/throttle body cleaner and spray everything in the carby.
Post Posted: Fri Sep 30, 2011 1:42 am
ok easy enuf :) i also moved the fuel pump and mounted it fixed could i have mounted to pump wrong ?
Post Posted: Fri Sep 30, 2011 1:59 am
Is it running the stock Mikuni grenade carby?
Post Posted: Fri Sep 30, 2011 2:21 am
yes it is
Post Posted: Fri Sep 30, 2011 4:48 am
Let's hope it's not the carb.
Check fuel pump by disconnecting fuel line input to carb and direct to a clear bottle. Turn ignition on and check for constant flow of fuel without hesitation. These little carbs need stuff all fuel pressure but do need a constant feed.
Hopefully it's the pump because these Mikunis are a POS.
Post Posted: Fri Sep 30, 2011 5:23 am
ok will do iv herd they are good carbys :S
Post Posted: Fri Sep 30, 2011 5:41 am
I dont know the type of carby set up, but its sounds like vacuum advance is not working.
If it was a fuel supply prob id feel it would splutter not lack power.
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Sep 30, 2011 10:00 am
I agree, although I am not familiar with this model suzuki it sounds like a vacuum hose has come loose or is broken causing a lack of suction for the advance. Had this problem a few times with cars from the 60's and 70's when I was young.
Users browsing this forum: No registered users and 337 guests
