Joined: Tue Aug 24, 2010 12:22 pm Posts: 500 Location: north richmond
Posted: Mon Oct 03, 2011 7:45 am
Hay fellas, do you know when you won't be able to get your lift (higher then 2in) engineered? Cause I really want to get a body lift and 31s engineered before then. And do you know if they will engineer a 2in body lift 2in spring and 31s?
Mine cost me $350, $200 for the first item and $50 for everything after that. Every engineer is different tho, some will say yes to anything and some no to everything. Best look around for a local engineer you can work along side of.
1) talk to engineer about all mods and ask how much it will cost.
2) ask engineer what the process is from that point onwards.
over here in WA theres kinda only one engineer worth talking to about 4wd mods, so its easy. from what i understand you guys have a lot of choice and can "shop around".
perhaps the better question to ask on here, is which engineer do people recommend for the mods you've done and your location...
Users browsing this forum: Google [Bot] and 137 guests
