It is currently Mon Aug 03, 2026 4:13 am
Post Posted: Mon Oct 10, 2011 8:42 am
to make your car cooling.Is thermo fans a good idea to put in.
Vehicle: Yellow Ute
Post Posted: Mon Oct 10, 2011 8:51 am
I got one on my zook, seems to have no trouble cooling it, it came with this crap 9 inch one but it was no good so I got a spal 11 inch and it has been good so far. If you get one just make sure you buy a decent one.
Vehicle: 02 jimny
Post Posted: Mon Oct 10, 2011 8:55 am
also good for water crossing switch it off to stop snapping blades and water being splashed all around your engine bay
LIVING LIFE ON THE EDGE, TILL YA ROLL
Vehicle: '94 suzuki maruti
Post Posted: Mon Oct 10, 2011 9:03 am
is it better to buy one from somewhere like supercheap or autobarn, or a good second hand one from a wrecker? new cheap brand or used OEM quality?
Post Posted: Mon Oct 10, 2011 9:14 am
It maybe be worth you having a peruse over this thread so we don't start the great vicous coupling vs thermo fan debate again...
http://www.auszookers.com/index.php?nam ... sc&start=0
Post Posted: Mon Oct 10, 2011 9:16 am
Oem quality is better. But they rarely are easy to bolt on.
Otherwise buy a qyality brand if you want to get longetivity out of it.
Post Posted: Tue Oct 11, 2011 6:18 am
Check the Lincoln mark IV type cars if you got any like that, and also minivans. They have a nice shrouded pancake fan that really pulls the air. The shroud fits perfect, and bolts through the supports.
Mine came from a minivan with a larger radiator, and two fans,. One had a bigger motor and no shroud, the one I pulled was off the other side of the radiator and it had a shroud and pancake motor.
Seriously the OEM's work excellent. I have not fond an aftermarket fan that can keep up with OEM used.
Post Posted: Tue Oct 11, 2011 6:43 am
http://auszookers.com/index.php?name=Fo ... ic&t=26657
:helloo:
More reliable.... :wink:
Users browsing this forum: No registered users and 314 guests
