Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
Posted: Thu Oct 13, 2011 5:27 am
All 1.3's have 6 of those. 2 under the front floor and 4 across under the front seats, 2 outside the chassis and 2 inside near the tunnel. The go under the chassis and yes the are required, you will need crush tubes that go up through both the upper and lower rubbers, about 40mm long.
Posted: Fri Oct 14, 2011 1:29 am
I have those rubbers available but you'll need to source the sleeves. The rubbers should be maintained with the bodylift as the body shouldn't be hard mounted
Users browsing this forum: Google [Bot] and 186 guests
