It is currently Sun Sep 20, 2026 6:00 pm
Vehicle: 02 GV
Post Posted: Wed Oct 19, 2011 5:54 am
Hey,
can anyone help me out with welding a bolt onto my diff and transfer filler plugs.
I want to change to oil in them.
Mine are to tight and now rounded. I have loosened the drain plugs but haven't emptied them yet luckily.
I tried using a chisel and hammer, I ground down a 3/8 to a perfect fit but didn't work and I can't weld at all, tried (i have no idea) to use my stick welder but lol, didn't work.
any help would be great. I'm on Brisbanes northside.
Vehicle: 1995 swb vitara
Post Posted: Wed Oct 19, 2011 6:50 am
you can get to the sides of the diff filler with a file then use a large open end spanner or a good shifter to open , worked for me
Vehicle: 02 GV
Post Posted: Wed Oct 19, 2011 6:52 am
it's an inny square drive.
so wont work for me.
Post Posted: Wed Oct 19, 2011 7:59 am
Can ya pound a square drive ratchet extension in there? Going to be harder to weld an inny, but the heat may help loosen it up too.
Post Posted: Wed Oct 19, 2011 8:02 am
Easy out 8)
Vehicle: 02 GV
Post Posted: Wed Oct 19, 2011 8:11 am
Rusho wrote:
Easy out 8)
was thinking this but but wont I get shavings inside the diff.
Post Posted: Wed Oct 19, 2011 8:17 am
When I did mine I drilled the hole at a very slow speed, let the oil drain out fully (took a while, small hole :cry: ) the drain plug is magnetic also :wink: You should be fine mate
Post Posted: Wed Oct 19, 2011 11:46 am
I'd suggest NOT using an easy out. I had the same problem with the diff filler plug and decided to use one. Long story short the friggin thing snapped and i was left in a worse position than when i started.
If it was to happen again i would definitely find someone to weld a small bolt or even a nut to the plug.
Just my opinion
Post Posted: Wed Oct 19, 2011 6:14 pm
Still have oil in it??????
Can you drive it to the south side????? :helloo:
I know a trick or 2.... :roll:
Vehicle: 02 GV
Post Posted: Thu Oct 20, 2011 12:35 am
Yeah I still have oil in it. I can drive to the south side.
That would be awesome if you could help me out. I'm working night shift this week so not free till monday though.
thanks
Users browsing this forum: Google [Bot] and 110 guests
