It is currently Wed Sep 23, 2026 12:01 am
Post Posted: Thu Oct 20, 2011 5:35 am
A mate of mine just bought a zook. He doesn't know much about them some brought it run for a look. First thing I noticed. Was a what appeared to be a air line from a air tank going to the transfercase. It's about a 90's WT. and his tcase shifting pattern is like a back to front lower case h. None of these gears engage the front drive shaft. I've attached some pics. It has receipts for a 6.1 reduction sumo case? Anybody shed some light? it hasn't got a air pump but has provisions to the tank for one.
Imagetank
Imagetop of transfercase.
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Thu Oct 20, 2011 5:39 am
Transfercase breather :D
Why its going into a tank im unsure.
Does it have hoses to the gearbox and diffs as well?
When in 4hi or low does the front shaft free spin?
If it doesn't it may just have siezed freewheeling hub.
We are amphibious
Post Posted: Thu Oct 20, 2011 5:46 am
sweet body lift haha.
I can only think of oil shooting into the tank if the case was pressurised..
Post Posted: Thu Oct 20, 2011 5:48 am
are you sure it goes to the transfer? looks like there is one coming off the tank going somewhere (probs compressor) and a separate breather for the transfer?
If you don't get stuck you aint tryin' hard enough
Post Posted: Thu Oct 20, 2011 5:55 am
looks to be one of Calmini's fine examples of booty fab. :P
Post Posted: Thu Oct 20, 2011 6:22 am
LOL that photo actually showed more then I could see! it's definitely breather.
No the front shaft only spins when in the gear that goes from neutral to the left hand leg of the backward lowercase h gear figuration. However when disengaging the clutch the car doesn't move at all.
Post Posted: Thu Oct 20, 2011 6:28 am
The clutch might need adjusting
Post Posted: Thu Oct 20, 2011 6:36 am
The clutch works fine in lw 2 and h2. It appears to have a l2 and a h2. The front shaft won't spin in l2 or h2.
Post Posted: Thu Oct 20, 2011 6:40 am
If the shaft isn't spinning in h2 then how do you know ur clutch is working in h2 :?
Post Posted: Thu Oct 20, 2011 6:48 am
sogone wrote:
The clutch works fine in lw 2 and h2. It appears to have a l2 and a h2. The front shaft[u] won't spin in l2 or h2.
Post Posted: Thu Oct 20, 2011 7:21 am
http://www.lowrangeoffroad.com/index.ph ... t-kit.html
Try that pattern.... :helloo:
Post Posted: Thu Oct 20, 2011 8:05 am
sogone wrote:
Did u edit that or am I just blind :lol:
Post Posted: Thu Oct 20, 2011 8:22 am
Nor should it!!!!
Post Posted: Thu Oct 20, 2011 8:29 am
steak_knife wrote:
Nor should it!!!!
x2 i was thinking that but then with all the 2h, 2l, nuetrals and clutches i got confused so didnt comment.
We are amphibious
Post Posted: Thu Oct 20, 2011 8:55 am
zooky08 wrote:
As a bat :)
Post Posted: Thu Oct 20, 2011 8:57 am
steak_knife wrote:
Nor should it!!!!
It has the stock Transfercase shifter knob. I was saying h2 and l2 cause it seemed to be thats what was selecting in the various positions. Gonna shave some of the body and see if we can get it further down and thn across right.
Post Posted: Thu Oct 20, 2011 10:13 am
Petroworks does one of these.
The Petroworks Split "H" Pattern Shift fork is a absolute must for a low gear transfer case. This "H" pattern gives you a the ability to drive in 2WD Low, but easily allows for switching to 4LO or 4HI.
There is another pattern you can get by just removing the detent ball called the sloppy "S" or sloppy "H", but I think it's an S pattern"
Basically when you remove the detent ball it gives you a true neutral and the ability to select 2WD low. The problem is that it can be a chore to find the gears.
HTH
-Sky
Users browsing this forum: No registered users and 218 guests
