It is currently Fri Oct 23, 2026 9:29 am
Post new topic Reply to topic  [ 82 posts ]  Go to page 1, 2, 3  Next
Post Posted: Sun Oct 23, 2011 5:46 am
Hey guys have been thinking, Im scared of braking stuff 4 wheel driving so iv decided to put 22's on the sierra. I have a set of 20's im going to use for now. Now my question is can i remove the hubs off the front of the car so i can fit the 20's should i disconnect the front tail shaft? And what do i replace the hubs with? Thanks for your helps guys i know use wont like my idea but i drive it every day and don't want to break stuff 4 wheel driving.
Post Posted: Sun Oct 23, 2011 5:48 am
sorry what..
Cant you get 22's with the right hole in the middle? or just run stock size wheels?
Post Posted: Sun Oct 23, 2011 5:50 am
Yeah i can but big money im just going to get them from the usa with a commo stud pattern cause i found stud converters.
EDIT- I just really wanna know about the locking hubs can i just remove them or what do i have to do?
Post Posted: Sun Oct 23, 2011 5:56 am
I had my front end apart the other day i cant recall there being an easy way for it to happen..
Why can't you use stock wheels and tyres? You wont break anything driving that to work and back.
Post Posted: Sun Oct 23, 2011 5:58 am
you can take the locking hub off however the end of the axle might still poke out to far
Post Posted: Sun Oct 23, 2011 6:00 am
I can but id like to add a bit of style to the sierra.
Post Posted: Sun Oct 23, 2011 6:01 am
Im gonna cry now lols. Can you just take the hubs off and drive?
Post Posted: Sun Oct 23, 2011 6:03 am
Try Boostcruising.com
You can get zook 5 stud, Try Fords f-100.
22"s on a sierra. Fail.
x2
Red softtop Sierra 2in spring 2in shackle 31at
pull the centre, front shaft and axles out. chuck in an empty third member. and fill the housing with dirt/rubbish cos of the holes haha.
Paint the stock rims black or chrome or something.
Or buy a commodore.
Post Posted: Sun Oct 23, 2011 6:04 am
this is why coily's are gay.
Post Posted: Sun Oct 23, 2011 6:05 am
No you cant
sorry to say it but if you are too scared to fix broken stuff then you dont have the skills to remove all the 4wd stuff, just go trade it in on a corolla or something
your stud converter idea is also stupid and dangerous
Yeah, could easily fit 30" rims geez :crazy:
Post Posted: Sun Oct 23, 2011 6:06 am
22s Gay very Gay
Post Posted: Sun Oct 23, 2011 6:07 am
Import a lazy axle from the usa, Coil convert it and cut all your springs in half, Sell your transfer(goodluck) and run it 2wd only with a longer tailshaft from the gearbox to the diff.
Post Posted: Sun Oct 23, 2011 6:08 am
Why would i buy a commo or a corolla when i drove a mercedes before the sierra bit of a fail there. So many haters why?
Post Posted: Sun Oct 23, 2011 6:09 am
buy an exel or something if you dont plan to 4wd
Post Posted: Sun Oct 23, 2011 6:10 am
isnt it sort of a 4wd forum ??
Nah wrong one mate.
Post Posted: Sun Oct 23, 2011 6:12 am
The only fail here is making a 4wd 2wd to fit some rims not designed to fit
why take something that drives shit on road to begin with and make it worse?
Post Posted: Sun Oct 23, 2011 6:13 am
You buy a 4wd to 4WD. Not buy a 4wd to only 2wd it because cos your scared. People will call you a soccer mum and if you get stuck on speedhumps in a 4wd, No one will snatch you.
Keyboard warriors just asked nicely for a little bit of help.
EDIT: For The nice ones if i just removed the hubs and drove would the axels fall out or what would happen?
Post Posted: Sun Oct 23, 2011 6:15 am
in2net wrote:
Keyboard samurai's just asked nicely for a little bit of help.
We are helping. Your not geting the idea. This is a 4wd forum. Not useless bling forum.
Post Posted: Sun Oct 23, 2011 6:17 am
Its a zok forum.
Post Posted: Sun Oct 23, 2011 6:18 am
australian suzuki 4x4 ???
Your diff will fall out too. Its not worth doing.
Righto here you go, I have every confidence in you not doing this
remove wheel
remove free wheeling hub
remove circlip from cv stub
remove rear part of free wheeling hub housing
remove caliper
remove rotor
remove the stub axle
remove CV and axle
refit stub axle
refit rotor
refit claiper
fabricate blanking plate where free wheeling hub was so bearing doesnt fill with dirt and fail
drain oil from diff so it doesnt fill up swivel hubs
you can leave the front shaft in so people dont get suss on your masculinity, but putting it in 4wd will eventually destroy the front diff that drives nothing anyway
Post Posted: Sun Oct 23, 2011 6:20 am
Why not make it fwd only?
now were talking
Post Posted: Sun Oct 23, 2011 6:24 am
remove wheel
remove caliper
remove rotor
remove CV and axle
refit stub axle
refit rotor
refit claiper
Is that it? man i hope so Thanks heaps. i wont put it in 4wd.
And is 250km to a tank normal for u guys or do i need to do a service and give the carby a good clean?
Users browsing this forum: No registered users and 140 guests
