It is currently Tue Sep 22, 2026 12:26 pm
Post Posted: Sat Nov 12, 2011 12:33 am
Where is the ground for the fuel sender? I've only got one wire that is the sender signal wire that runs up into the body loom then into the guage cluster. I've checked all the earths for the guage cluster and body yet my guage still isn't working. I'm assuming the sender needs an earth.
Post Posted: Sat Nov 12, 2011 12:39 am
It's probably earthed through the body of the sender.
Post Posted: Sat Nov 12, 2011 12:43 am
Mmmm. Odd. It all appears to be earthed and everything connecte.
Post Posted: Sat Nov 12, 2011 12:46 am
No reading, or incorrect reading?
Some good tech here.
Post Posted: Sat Nov 12, 2011 1:05 am
It was working semi fine, had a problem with reading at all. So I did the fix that you linked. Made sure it all connected properly and was gunk free. Assembled. Then changed the body over to the tin top, wired up my 1.6 baleno and a few other things. Now it won't work. Just sits on the very bottom.
Users browsing this forum: Google [Bot] and 188 guests
