It is currently Wed Oct 14, 2026 12:46 am
Post Posted: Tue Nov 15, 2011 7:45 am
Hey all just wondering what oil ya all run in ya transfer case with reduction gearing?
Also what oil people run in there gear boxs?
back in a built sierra!
Post Posted: Tue Nov 15, 2011 7:47 am
Castrol 80-90 gear oil in both 8)
Post Posted: Tue Nov 15, 2011 7:49 am
Cheers bloke....is that the best for both? i looked on the net and it come up with 3 or 4 different ones.... :?
That's what I use too.
Post Posted: Tue Nov 15, 2011 7:51 am
More convienient and economical to use the same oil, I use it for my diffs also :lol:
Post Posted: Tue Nov 15, 2011 8:04 pm
Convenient & economical as it may be, you're taking a bit of a chance - differentials usually require an EP or GL-5 oil, some of which can be detrimental to the health of gearbox synchros where a GL-4 is the coorect choice.
If you can find an EP or GL-5 that is safe for use with brass & bronze (so called yellow metal friendly), then by all means use it all around - I use Mobil One 75w90 full synth.
Post Posted: Wed Nov 16, 2011 7:22 am
how much do both take? all up
Post Posted: Wed Nov 16, 2011 7:36 am
2.1 litres 8)
Post Posted: Wed Nov 16, 2011 7:37 am
Castrols EPX 75W/80 and 80W/90 can be used in both. The thinner one is recommended for transaxles whilst the thicker is for some car and truck gearboxes
Post Posted: Wed Nov 16, 2011 8:16 am
I have allways run 80w-90 with out any probs
 Profile YIM
Post Posted: Wed Nov 16, 2011 5:25 pm
Check the valvoline website. Will tell you what you need
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Wed Nov 16, 2011 5:59 pm
You're free to use whatever you chose, however, here's an extract from the Castrol EPX data sheet.
[quote=castrol]The Castrol EPX Gear Oils contain sulphur-phosphorus extreme pressure additives which enable them to withstand high rubbing
speeds and tooth pressures.[/quote]
Sulphur is one of the additives KNOWN to attach the bronze & brass components, and no where in the data sheet did it mention anything about the oils being safe for use with brass/bronze or yellow metal friendly.
From a Mobil One data sheet
[quote=Exxon-mobil]Excellent rust, staining and corrosion protection of copper and its alloys[/quote]
Brass & bronze are alloys of copper, so Exxon-Mobil are being very specific - corrosion protection of copper and it's alloys.
This is the reason I'm using Mobil One - along with the fact that I can feel the difference in the way the transmission shifts.
From Shell Australia on Shell Helix 75W90
[quote=Shell Australia]Protects synchro rings against corrosion[/quote]
I'd use that in a transmission.
Post Posted: Wed Nov 16, 2011 8:54 pm
Castrol VMX80 for gearboxes(1.3l) and transfers(0.8l). Now called VMX-M
Castrol EPX 80W/90 for differentials. (rear 1.3l) (front 1.5l)
http://www.datateck.com.au/lube/castr_au/default.asp
Post Posted: Thu Nov 17, 2011 5:07 am
thanks guys!
Users browsing this forum: No registered users and 228 guests
