It is currently Fri Oct 09, 2026 3:11 am
Vehicle: On the lookout
Post Posted: Thu Nov 24, 2011 11:37 pm
Woohoo,
Sourced an M18 and ECU to go in my jimny to replace the M13!
Read up all the conversions threads on the forum. Still struggling to grasp every detail but basically I'm going to use the M18A Block, head and Injectors. Everything else will be Jimny. Jimny clutch, flywheel, intake and exhaust manifolds, sump etc...
Once I have it running I'll drive it to the local dealership on the M13A ECU and then pop the M18A in and have them program the immobiliser code to match the jimnys. (Although I'll give the M18 ECU a go before I take it on the wild chance that it might have been programmed with the same code - you never can be sure!)
Then I'll get it engineered and all is sweet I hope!
Post Posted: Thu Nov 24, 2011 11:45 pm
would be cool if you could document the install & do a write up for AZ, i'm sure there are others including myself that are interested in the conversion. :wink:
Vehicle: 4wd
Post Posted: Thu Nov 24, 2011 11:58 pm
x2
Take your time, loads of pics, and lots of description :D
Goodluck!
Watch out or you'll get sued.
Post Posted: Fri Nov 25, 2011 6:41 am
Yeah, I just got it home and had a look. The guys left everything on except the exhaust manifold and the Flywheel. SO essentially I have a complete engine, I'll certainly be using everything M18 that I possibly can, definately be using the M18 intake now I know that I have it. Its looking good.
Crispy old grand vitara
Post Posted: Fri Nov 25, 2011 6:44 am
It's a lightweight engine, I manage to cling a rope over and shoulder and carry out of the back of the van on my own. I reckon I'll probably be getting more power at no expense in terms of weight, although the fuel economy might take a hit, although possibly not since I won't be thrashing it everywhere anymore.
Post Posted: Fri Nov 25, 2011 8:34 am
drewmouli wrote:
make sure you use the M18 intake!!!!!!!! M13 is horrible, restricts the power at 5000rpm and backs right off. The correct manifold I found powers constantly to the rev limit
What's the difference???
Post Posted: Fri Nov 25, 2011 9:07 am
I want to see the difference between the m13a and m18a ECU when the car's are put on the dyno....*cough*Drew*cough* :wink:
Post Posted: Fri Nov 25, 2011 10:14 am
Yep,.. still waiting on that...
Vehicle: 2001 M18a Jimny
Post Posted: Fri Nov 25, 2011 10:50 am
drewmouli wrote:
Its larger on the inside, aka more flow at higher RPM
Is there a way to tell them apart visually? As I'd like to know which one is on mine.. Hope it's the m18's original!
http://www.facebook.com/omalleyimagesonline
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Nov 26, 2011 8:21 am
Squib, I want to come for a drive when it's done :D
Post Posted: Sun Nov 27, 2011 3:01 am
Has anyone dynoed the stock M13AA (M13A with VVT) engine yet? Thats what I got as standard i think according to wikipedia. The aim of all this conversion is to be able to hold 110kph uphill, this is absolutely not possible at the moment even when I drop a gear or even two. I ain't planning on burning rubber everywhere I go.
Post Posted: Sun Nov 27, 2011 3:17 am
M15 will do that with ease.... :helloo:
Post Posted: Sun Nov 27, 2011 3:29 am
Not up my hill :)
Post Posted: Sun Nov 27, 2011 3:34 am
:roll:
Post Posted: Sun Nov 27, 2011 5:20 am
My m13a with 31's can hold 110kph up hills :roll: but i do have reduction gears :helloo:
Post Posted: Sun Nov 27, 2011 7:02 am
well this is the thing, I'll probably be able to get by without reduction gears even if I go big tyres in future with the M18 so thats that decision. hell of a lot more torque. The M15 has 100hp more or less, which is generally enough to shift any small vehicle pretty well. But on the same basis, I've had plenty of cars with 85bhp like the M13, but none of them have been anything like as slow as the jimny. So the drivetrain must sap a lot of power. 100hp from the M15 might still feel a bit lame, so I've gone bigger.
Post Posted: Sun Nov 27, 2011 7:12 pm
Bigger tyres (more rolling resistance), bad aerodynamics, yes driveline friction, etc. Also, more weight due to two gearboxes, two extra shafts, extra diff.
My 1.3 Jimny is fast though, will hold 110km/h uphill with the A/C running. It can also pull a tonne behind it... Just! :roll:
Post Posted: Sun Nov 27, 2011 10:24 pm
:lol:
Lil Foot!
Post Posted: Sun Nov 27, 2011 10:39 pm
:lol:
Of course i'd still like a bigger motor :wink:
Post Posted: Mon Nov 28, 2011 2:32 am
Mate, you got a good one if it'll hold 110kph uphill on 215 tyres or larger. Best not to mess with it.
My M13 couldn't pull the skin off a rice pudding.
Post Posted: Mon Nov 28, 2011 3:43 am
Gears are good :wink:
Post Posted: Mon Nov 28, 2011 8:20 pm
Shorter Gears = Better tool
Bigger Engine = Bigger Hammer
Users browsing this forum: No registered users and 197 guests
