It is currently Thu Sep 24, 2026 8:11 pm
Post Posted: Fri Dec 02, 2011 4:56 am
G'day
Just after some help in what part of the diff you belive to have failed.
Video has full details
http://www.youtube.com/watch?v=F0dGHvQPigg&sns=em
Liam
Post Posted: Fri Dec 02, 2011 4:59 am
Well I would pull the axles out, then remove the diff and then we will all know. :-)
I'm beting side / spider gears or pinion gear or crown wheel. :-) ooh could be bearing. That's about all that is in there so I must win.
Post Posted: Fri Dec 02, 2011 5:34 am
Spider gears are fine. Run the car in gear (2WD) up on the axle stands and stick ya head under (with or without camera) and tell us where the noise is coming from.
Post Posted: Fri Dec 02, 2011 6:02 am
The noise is coming from the diff pumpkin and towards the end of the passenger side axle tube.
Post Posted: Fri Dec 02, 2011 6:03 am
Pull it out and have a look then. If it's damaged then you gotta get it out anyway
Post Posted: Fri Dec 02, 2011 7:12 am
Carrier bearings
Post Posted: Fri Dec 02, 2011 7:56 am
zooky08 wrote:
Carrier bearings
ahhhh.....no.
That is 1.03 minutes I will never get back........ :roll:
Pull things apart and it will be obvious what is wrong.
Post Posted: Fri Dec 02, 2011 8:00 am
joeblow wrote:
zooky08 wrote:
Carrier bearings
ahhhh.....no.
That's what I was trying to say :wink:
Post Posted: Fri Dec 02, 2011 11:01 am
I didn't even watch the clip :lol:
Vehicle: '94 suzuki maruti
Post Posted: Fri Dec 02, 2011 8:38 pm
when both wheels are in the air and the cars in gear and you have an open centre (no locker), when you spin one wheel the other should spin the opposite direction.
have you checked wheel bearings?. while the cars on the stands still with the wheel in the air, grab both the top and bottom of the wheel and try to wiggle it , see how much play it has...
Post Posted: Sat Dec 03, 2011 1:45 am
Found the problem, diffs fine it's a stuffed wheel bearing making all the noise. My moment of stupidity wandering why my wheels wear spinning of the ground in gear. Should of done the bearing when I replaced the axle seals.
Thanks for the help
Liam
Users browsing this forum: Google [Bot] and 145 guests
