It is currently Mon Jul 27, 2026 9:17 pm
Vehicle: 2" lift, 215 a/t
Post Posted: Mon Nov 28, 2011 9:56 am
Hey guys my jimnys got a tow bar but no point to plug in for the lights. I was going to tap into the tail lights to run the cable but saw something on google about an adapter clip you can buy and plug in somewhere. Any ideas on the easiest way to do this?
Post Posted: Mon Nov 28, 2011 10:15 am
I assume this is what you are talking about
http://www.narva.com.au/products/browse ... swire-taps
Post Posted: Mon Nov 28, 2011 7:01 pm
i believe hes meaning a plug n play loom, which is available on many larger 4x4s but i really have no idea for a jimny, but those wire taps are evil
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Mon Nov 28, 2011 7:07 pm
On my Jimny, the wiring loom runs up behind the right rear tail light.
You unplug the plug behind the brake light and plug in the loom between that and the existing plug. If that makes sense ?
TasZooks
http://www.facebook.com/TasZooks
Post Posted: Mon Nov 28, 2011 9:26 pm
What part of brissie you in?
Post Posted: Mon Nov 28, 2011 9:35 pm
try www.parksidetowbars.com.au - they have "wire safe" looms - not sure about jimny but you might get lucky.
Post Posted: Tue Nov 29, 2011 1:23 am
I'm in Albany creek in brissy. Yeah was basically after a plug and go loom to avoid tapping in. Hopefully I can get one to adapt onto somewhere near the tail lights? Thanks for the websites guys I'll check them out
2" lovells lift, snorkel, 215/75/15 A/T's
Post Posted: Sat Dec 03, 2011 2:39 pm
No one else knows of any plug and play trailer looms?
Post Posted: Sat Dec 03, 2011 6:36 pm
Suzuki make em, but......... $$$$$'s......
Could be worth a look, may not be to much...
Post Posted: Sat Dec 03, 2011 11:36 pm
why not just tap into the original loom .. why do you want a plug in set up
or come to me and i will do it for you..
easy as and will save you some $$$.. cost you about $30 tops on parts..
Post Posted: Sun Dec 04, 2011 7:51 am
Yeah I am planning on tapping into it but though if there was a plug and play it would be a big easier. I suppose I'll just cut the wires and solder some new ones on for the trailer no big deal.
Users browsing this forum: No registered users and 368 guests
