It is currently Fri Nov 13, 2026 10:33 am
Vehicle: 91 Tin Top, 04 Jimny
Post Posted: Sat Dec 17, 2011 1:13 am
:helloo: Looking at modelling a chassis of a SWB Leafy WT in solidworks and was chasing some solid dimensions.
I've got the dimensions off suzuki info, but this isn't detailed enough, and using a tape measure on my zook isn't nearly detailed enough either...
So if anyone has a good image of the swb chassis on their computer, or can point me to a good image on the www that would be legendary.
Cheers :wink:
[This here is what I already have, Suzuki Info]
Post Posted: Sat Dec 17, 2011 1:36 am
Why are you going to the effort of making a full new chassis?
WT chassis's are everywhere.
It will have to be registered as a ICV if road going. Alot more engineering involved.
Post Posted: Sat Dec 17, 2011 1:55 am
I'm not going to be making an actual chassis, I would just like to model it in solidworks in order to play around with link suspension and clearances.
Should have been more clear in my first post, have edited now.
It's very early days, but I would like to start modelling the chassis and diffs in advance.
Post Posted: Sun Dec 18, 2011 8:48 am
http://www.scribd.com/doc/21673819/Suzu ... Spec-Sheet
Post Posted: Sun Dec 18, 2011 9:09 am
Cheers for that christover,
It was helpful, but I am chasing more detailed information - it might not even exist, but I figured that maybe someone on here knew?
Specifically I am looking for the dimensions relating to the bends in the chassis and the bend radius
Post Posted: Sun Dec 18, 2011 9:16 am
http://www.suzukiinfo.com/sierra/samura ... nsions.jpg
Post Posted: Sun Dec 18, 2011 9:21 am
christover1 wrote:
http://www.suzukiinfo.com/sierra/samuraichassisdimensions.jpg
In my first post ^^
Cheers anyway mate, I might pm a few of the blokes on here see if they know anything...
Post Posted: Sun Dec 18, 2011 9:23 am
C:\Users\christover\AppData\Local\Temp\svg7.tmp\svhc.tmp\FEM_ReportExample.htm
Sorry if these are useless. But may point you to something useful
Post Posted: Sun Dec 18, 2011 9:24 am
oops didn't see the already have bit :oops:
Post Posted: Sun Dec 18, 2011 9:25 am
Very useless, they are stored on your computer that we don't have access to :helloo:
I want my old sig back :(
Post Posted: Sun Dec 18, 2011 9:26 am
Haha, that's no worries mate
What's this one? (other than a a link to your temp date on your comp? :lol: )
Edit: Beaten to it ^^
Post Posted: Sun Dec 18, 2011 9:34 am
http://www.kmitl.ac.th/~kpmonsak/FEM/FE ... xample.doc
It was an odd l;ink, had to work it out.
But it not much use any way
Post Posted: Sun Dec 18, 2011 9:41 am
That's pretty close to what I want to do in terms of modelling - not any of the analysis stuff though.
The final paragraph in that document pretty much sums up my problems... Just with bad grammar :lol:
So anyway, this chassis is not the same of the real chassis of the SJ413. The real chassis has the bend area that may not stronger than this chassis. The problem of me why not create the real dimension is because the blueprint does not have the exact dimension about the bending area on the side view so I cannot drawing it correctly.
Post Posted: Sun Dec 18, 2011 3:34 pm
Maybe see if Joeblow can scan one for u or he might already have
Users browsing this forum: No registered users and 60 guests
