| Author |
Message |
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sun Jan 15, 2012 9:52 pm |
Driving style for sure. just watched the video and you have throttle why coming down off stuff so you hit the back side, wheel bites in and something has to give. its going to be you center or cv when that happens.
drop your tyre pressure and try using less revs. a set of gears will let idle up most stuff
ZookFan
Joined: Mon Feb 14, 2011 6:19 am Posts: 3978 Location: Brisbane,samford,QLD
 Posted: Mon Jan 16, 2012 12:49 am |
Bugsta wrote: Aww really? Thats a shame. Perhaps is because hair dressers rarely go off road. . gold!
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Mon Jan 16, 2012 12:54 am |
Joe can make Sierra hub and cromo cv will fit outer but still needs to work out a inner
If he could make a slip axel with a uni on the inner that might work
Then he could make new stub axels to suit the uni bolt pattern
swifty_ano
Joined: Tue Jun 29, 2010 4:17 am Posts: 1664 Location: Brisbane, QLD
 Posted: Mon Jan 16, 2012 3:28 am |
got_bar_work wrote: Joe can make Sierra hub and cromo cv will fit outer but still needs to work out a inner If he could make a slip axel with a uni on the inner that might work Then he could make new stub axels to suit the uni bolt pattern
Has this been tried and tested? How do they go?
I haven't ever seen a broken inner?
swifty_ano
 Posted: Mon Jan 16, 2012 3:34 am |
By the way. The only I drove it so hard then was because if the car had lost traction and slid into the hole I wouldn't have a vitara.
Very slippery rock and big holes lol
But the concensus with my friends is that the CV shouldn't have broken under that little load.
What is everyones thoughts? Should it have definately broken? Or is it what stekky said, just old CV's
tanshi
 Posted: Mon Jan 16, 2012 3:36 am |
look into the hilux IFS cv mod,
Locked vits break CVs. some people can manage to survive, but on average you will break them.
swifty_ano
 Posted: Mon Jan 16, 2012 3:45 am |
tanshi wrote: look into the hilux IFS cv mod,
Yeah mate. I am currently in talk with a fabricator working out my options.
But no point in making a cheap weak point stronger and making a more exspensive part the new weal point.
Anyone know what other CV's may suit?
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Mon Jan 16, 2012 3:47 am |
Yep unfortunetly, if thats the terrain your looking to drive in a vitara its going to happen. Whether often or not expect them to go.
I would be getting a sierra if that was the terrain i was driving.
_________________ Chop
tanshi
 Posted: Mon Jan 16, 2012 3:55 am |
swifty_ano wrote: tanshi wrote: look into the hilux IFS cv mod,
Locked vits break CVs. some people can manage to survive, but on average you will break them. Yeah mate. I am currently in talk with a fabricator working out my options. But no point in making a cheap weak point stronger and making a more exspensive part the new weal point. Anyone know what other CV's may suit?
people uprate CVs because they arent a cheap "fuse" part. If you drive hard terrain your always going to break something eventually, but cvs shouldnt be breaking as easy as they do.
as an example, i was at a club comp a few months back, we had a mix of sierras, LJs and Vits. the vits broke 5cvs over a weekend i believe, sierras broke 1. ljs none.
you might also consider not always driving locked. try stuff unlocked first, it teaches you to be a better driver. then lock one diff and try again, only if you really need to, lock the front, the less you used it, the less your going to break.
atari4x4
 Posted: Mon Jan 16, 2012 5:30 am |
tanshi wrote: swifty_ano wrote: tanshi wrote: look into the hilux IFS cv mod,
Locked vits break CVs. some people can manage to survive, but on average you will break them. Yeah mate. I am currently in talk with a fabricator working out my options. But no point in making a cheap weak point stronger and making a more exspensive part the new weal point. Anyone know what other CV's may suit? people uprate CVs because they arent a cheap "fuse" part. If you drive hard terrain your always going to break something eventually, but cvs shouldnt be breaking as easy as they do. as an example, i was at a club comp a few months back, we had a mix of sierras, LJs and Vits. the vits broke 5cvs over a weekend i believe, sierras broke 1. ljs none. you might also consider not always driving locked. try stuff unlocked first, it teaches you to be a better driver. then lock one diff and try again, only if you really need to, lock the front, the less you used it, the less your going to break.
this
tombutt
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1917 Location: brisbane
 Posted: Mon Jan 16, 2012 6:55 am |
thats how i drive rear locker always gets the flick before the front but will always try something unlocked first and gears make it much easier in terrain where you will lift a tyre as everything happens slower ie you lift a tyre and feel it lift so can back off so your not on the gas when it comes down or if you have to be you can have the tyres turning that slow it doesnt matter anyway i think with the harder stuff im trying to drive now with out gears id be chewing through cv's every time i go out
jesse_vit
Joined: Wed Sep 22, 2010 8:57 am Posts: 324 Location: Gold Coast
Vehicle: stock yellow vit.
 Posted: Mon Jan 16, 2012 7:54 am |
swifty_ano wrote: got_bar_work wrote: Joe can make Sierra hub and cromo cv will fit outer but still needs to work out a inner If he could make a slip axel with a uni on the inner that might work Then he could make new stub axels to suit the uni bolt pattern Has this been tried and tested? How do they go? I haven't ever seen a broken inner?
i have broken 2 drivers side inners iff in the diff center.
atari4x4
 Posted: Mon Jan 16, 2012 8:07 am |
jesse_vit wrote: swifty_ano wrote: got_bar_work wrote: Joe can make Sierra hub and cromo cv will fit outer but still needs to work out a inner If he could make a slip axel with a uni on the inner that might work Then he could make new stub axels to suit the uni bolt pattern Has this been tried and tested? How do they go? I haven't ever seen a broken inner? i have broken 2 drivers side inners iff in the diff center.
22 spline or 26 spline & where is it breaking
got_bar_work
 Posted: Mon Jan 16, 2012 6:21 pm |
Never seen a inner break
I pulled the cir clip grove off one when I did my widening mod before I welded on a spacer onto the stub axel
steak_knife
 Posted: Mon Jan 16, 2012 7:30 pm |
got_bar_work wrote: Never seen a inner break I pulled the cir clip grove off one when I did my widening mod before I welded on a spacer onto the stub axel
I have, smashed it.....
steak_knife
steak_knife wrote: got_bar_work wrote: Never seen a inner break I pulled the cir clip grove off one when I did my widening mod before I welded on a spacer onto the stub axel I have, smashed it.....
2 of em, than took out diff drop bracket's & all fixed, never did another one....
got_bar_work
 Posted: Mon Jan 16, 2012 10:36 pm |
Did u have bump stop spacers with ur diff drop brackets
U might of had to much uptravel and the inner probly Jammed up
I have big drop brackets like 40-50mm but I have big bumpstop spacers In my lower coil spacer
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Mon Jan 16, 2012 11:31 pm |
I have never owned a Vitara but is that video for real or is it just taking the piss, I'm not sure if I would have even engaged four wheel drive in the LJ for that hill.
tanshi
 Posted: Mon Jan 16, 2012 11:37 pm |
i think its a fair bit steeper than it looks, but honestly i sure as hell wouldnt have locked a diff to climb it
tombutt
 Posted: Tue Jan 17, 2012 12:35 am |
That hill is actually pretty steep its down behind the fire tower swb cars shouldn't really need a locker on it hiluxs struggle on it but that's just there wheel.base my lwb normally gets up unlocked. Id try crawling next time swifty
2stroker
 Posted: Tue Jan 17, 2012 2:19 am |
I was just having fun.....
swifty_ano
 Posted: Tue Jan 17, 2012 3:58 am |
The only reason the I put the locker on was because it took a lot of convincing to even try it. My mate in his patrol tried it unlocked and struggled a lot and he had bigger tires and a 5lt v8. And if you start sliding on that hill you'd end up in the ditch. Just a precaution.
2 stroker, can I actually see you try it in 2wd. I actually think it would make it. If not, we will have a vitara near by to tow you up
tombutt
 Posted: Tue Jan 17, 2012 4:28 am |
swifty dont be fooled by patrols struggling alot of the time they will struggle up something and i will climb up easy its a wheel base thing
DSzuke
Joined: Mon Jun 22, 2009 11:30 pm Posts: 108 Location: Orange
 Posted: Tue Jan 17, 2012 4:55 am |
I had a run of breaking a few.
I tried a few solutions and don't really know which one worked but have had success with...
Adjusting the steering so full lock is not beyond the limits of the cv.
Removing the air-locker and running a lockrite.
Adjusting driving style so that I drive hard bits with the wheels as straight as possible.
Running two-wheel low range when 4wd isn't needed.
I don't think this is related but I did the passenger side into drivers side conversion to make it easier to change them and would you believe I haven't busted one since!?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Tue Jan 17, 2012 5:02 am |
DSzuke wrote: Removing the air-locker and running a lockrite.
Are you claiming these things are helping to save CV's? I can't see how a lock wrong is easier on the CV's than an air locker. As for using 2 Low, I'd be hoping that anywhere you could drive in 2 low you weren't in danger of blowing a CV of you were in 4 low.
the other things you pointed out were totally valid IMHO. Also, watch reverse at full droop/full lock. It's harder on the CV's than going forwards.
tombutt
 Posted: Tue Jan 17, 2012 5:03 am |
i can see a auto locker in theory has more give in it then a air locker but if its slipping then its not doing its job
Gwagensteve
 Posted: Tue Jan 17, 2012 5:30 am |
How so? Have you seen an auto locker "slip" - they are incredibly violent on the axles when they do "slip".
I think to be able to unlock the diff when bound up, an air locker has the potential to be much softer on the axles.
I actually think an auto locker is harder on axles than a spool.
tombutt
 Posted: Tue Jan 17, 2012 5:44 am |
i said in theory there is a reason why i have a air locker not a auto to me a auto in the front would be acting like a tyre gain grip then loosing it then gaining agin suddenly to me on a high traction surface something would give in that situation and in a vitara that would be the cv
DSzuke
 Posted: Tue Jan 17, 2012 6:01 am |
Gwagensteve wrote: Are you claiming these things are helping to save CV's? I can't see how a lock wrong is easier on the CV's than an air locker. As for using 2 Low, I'd be hoping that anywhere you could drive in 2 low you weren't in danger of blowing a CV of you were in 4 low.
I'm not sure Steve. I blew a few in a row and then none for close to two years now. I don't know which of the changes made the difference.
I actually put the lock-rite in only because I had a 26 spline one sitting there when I did the diff upgrade. The airlocker was the old 22 spline (still haven't got around to changing it).
I think maybe doing the majority of driving in 2-low when possible is probably saving wear and tear on the cv's as they are not under load all the time.
In the end I think either locker gives you the ability to drive slow and in control which prevents the wheel spin that kills the cv when you hit the rock ledge that put it up in the air
swifty_ano
 Posted: Wed Jan 25, 2012 4:08 am |
Just if anyone is interested.
The latest issue of 4wd action roothy does glasshouse. Roothy does the hill in my video and it shows how steep it really is
