It is currently Wed Aug 05, 2026 2:07 am
Post Posted: Sun Jan 22, 2012 1:50 am
hey all
just put a deposit down on a 98 jimny going to pick it up on tuesday and it had a bit of a gargleing type noise hard to explan and the guy said it's the ps pump regulator it had a bit of a vibration in it also does this sound right? and if so how would i fix it?
if u drive a loud toyota ute u drink rum
Post Posted: Sun Jan 22, 2012 10:41 am
any ideas
Post Posted: Sun Jan 22, 2012 11:15 am
Sounds like what happens when the pump cavitates.
The system may need bleeding to remove air bubbles.
Post Posted: Sun Jan 22, 2012 12:18 pm
ok so i might not need to get a new ps box then
Post Posted: Sun Jan 22, 2012 12:30 pm
PS box can fail in a few ways. Leaks ( very obvious ) or damaged internals. Damaged internals usually present as a lumpy movement.
The shudder and noise you described is similar to that of when a PS system is running low on fluid, or has air trapped in the lines.
What you would be better off doing is taking it to a unbiased mechanic BEFORE handing over any more cash.
Post Posted: Sun Jan 22, 2012 12:39 pm
yea its a pretty cheap car so i expected a few problem's ill probs just have a good look into it when i get it ill try bleeding it first and if that doent work there's a jimny at the wrecker near by ill get a box of that thanks for the help
Post Posted: Sun Jan 22, 2012 12:43 pm
Could be the pump also. So if it doesn't bleed up and you do hit up the wreckers, get the whole setup. Should be less than $700.
Post Posted: Sun Jan 22, 2012 12:53 pm
ive heard a 88 camery low on ps fluid and it doent sound like this 1 so does that mean its not low or do all cars make different noise's when low?
Post Posted: Sun Jan 22, 2012 1:02 pm
They are all fairly similar sounding. Like a groaning noise.
It doesn't sound like a bearing noise does it? Could be the pulley bearing on the pump?
Post Posted: Sun Jan 22, 2012 1:05 pm
not really it's not a whine it kinda sounds like some1 gargleing mouthwash
Post Posted: Sun Jan 22, 2012 8:37 pm
sure its not boiling?
Post Posted: Sun Jan 22, 2012 11:44 pm
i dont think it is
Users browsing this forum: No registered users and 738 guests
