It is currently Fri Oct 02, 2026 5:12 pm
Post Posted: Thu Mar 19, 2009 9:31 pm
would anybody or everybody like to climb underneath and take a pic of the clutch arm the cable attaches too?
and possibly measure how long from centre of the splined hole bit to where the cable attaches?
more the merrier and everyone can have a go regardless of model, might even make it the next photo comp :)
I am having dramas with my clutch and at least know now how much the throwout needs to move (8mm) to release the pressure plate and give the clutch disc enough room (1.5mm) jsut have to now figure if the pedal is pulling the cable enough to swing that arm enough to push the throwout 8mm, if my arm is too long (reckon it could be) then it would explain my probs
Post Posted: Thu Mar 19, 2009 9:39 pm
mine is hydrolic? :? :?
Post Posted: Thu Mar 19, 2009 10:28 pm
then you are excused and cant win the comp :P
Post Posted: Thu Mar 19, 2009 10:29 pm
and for more cool info, the cable needs to pull the arm 20mm to get the throwout to move 8mm (on mine at least)
Post Posted: Thu Mar 19, 2009 10:34 pm
i even took a pic, but when i re~read your post i realised that the 1.6L are cable & the 2.0L is hydrolic.
i didn't even bother to upload it to photobucket, i can photoshop it so it looks like a cable clutch if that helps or isn't photoshop allowed in this photo comp??
Post Posted: Thu Mar 19, 2009 10:42 pm
noobcad mebbe?
Post Posted: Thu Mar 19, 2009 10:50 pm
no photoshop, only noobcad :)
Post Posted: Thu Mar 19, 2009 11:01 pm
Only thing I can find is this nob trying to fix a vit.
Will have Lulas up on the hoist Sunday I will get what you want and If you have your Ph on and except my call that may help also
Steve W
Post Posted: Thu Mar 19, 2009 11:06 pm
long as its outside work hours otherwise I wont answer
even the Daikin engineers are interested now :wink:
Post Posted: Thu Mar 19, 2009 11:13 pm
Dahhhh...So you work there S U N D A Y S as well now.
Steve W
Post Posted: Thu Mar 19, 2009 11:15 pm
I am still here now, rate I am going I will
actually racing Sunday, no service at Willowbank
Post Posted: Thu Mar 19, 2009 11:18 pm
Excuse me sir but can you put a pic of what you want from where to where and where the
"and possibly measure how long from centre of the splined hole bit to where the cable attaches?"
I will go to the back of the class again sir.
Steve W
Post Posted: Thu Mar 19, 2009 11:36 pm
as far as i know all vitara manual non hydraulic arms are the same. they are pressed from steel and have two fillet welds in them. i don't think the sierra arm will fit as it has a smaller spline and are cast steel. the only times i have come across this type of drama is when
a) the clutch is a crappy rpm or pbr product.
b) the cable mount in the firewall has craked allowing movement.
c) the cable has a tear or split in the outer sheath allowing excesive movement.
sorry......thats all i got......
Post Posted: Fri Mar 20, 2009 12:10 am
http://www.johnpaul.3leggedcat.net/IMG_6027.JPG
is that what ur after??
Post Posted: Fri Mar 20, 2009 1:05 am
I had dramas with mine when I put in a new Exedy (daikin) clutch. It would not disengage the whole way, and could not get it adjusted for the life of me.
The problem was that the cable was buggered, I had a look at it when I took it out, and I think it had a kink in the middle of it somewhere causing it to get stuck in a different position to where it was used to being used. How old is your clutch cable?
Post Posted: Fri Mar 20, 2009 2:01 am
this is an exedy too, same thing cant get it right
cable is 2 weeks old now, problems been around since january and all jsut went to shit this week
morpheous, is that a vitara? I thought they all had the rubber grommet style cable
Joe, looked at the firewall, all ok, unless the pedal box is flexing where I cant see
Vehicle: Clown Car..
Post Posted: Fri Mar 20, 2009 2:15 am
Links suck.... :lol:
EDIT: HOLY BEJESUS THATS A BIG P\CTURE!
Post Posted: Fri Mar 20, 2009 2:50 am
ha yeah sorry, thats why i posted a link and not the picture. figured the large size and quality might b of use so u can get in close to see what ur after..
and royce
yeah thats a 93 model 1.6 vitara GLX..
but who knows what random dodgey crap has been done 2 it 2 make it work.. i bought it dodged up and blown.
:-( still so sad...
Post Posted: Mon Mar 30, 2009 6:29 pm
is there an alternative to exedy apart from custom, I havent been happy with their stuff for years.
Users browsing this forum: Google [Bot] and 130 guests
