It is currently Wed Nov 04, 2026 10:00 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
Vehicle: chick magnet coily
Post Posted: Sat Apr 14, 2012 7:27 am
hi everyone
i've been thinking of getting a welded centre and was wondering if
it would make a difference on the beach?
and does it effect steering greatly?
thanks max
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Sat Apr 14, 2012 8:10 am
Yes. and you'll want chromo's otherwise you'll be snapping CV's all the time
Post Posted: Sat Apr 14, 2012 8:17 am
Not going to happen....'fully sick COILY' user name :wink:
Yes and suck it and see. I have a spare set of cv's :mrgreen:
Post Posted: Sat Apr 14, 2012 8:19 am
Rusho wrote:
SierraDan wrote:
Yes. and your car is gay
Fixed.
Post Posted: Sat Apr 14, 2012 8:49 am
You shouldn't need lockers for the beach in a Sierra and a permanently locked front will suck in the sand I reckon, sand is one place where I value quick light steering. If you're not locked rear then I suggest doing that first.
Post Posted: Sat Apr 14, 2012 8:54 am
Locked rear in sand is awesome. Twin locked with a welded front in sand sucks.
Post Posted: Sat Apr 14, 2012 9:22 am
what do you mean by this?
Post Posted: Sat Apr 14, 2012 9:38 am
Coily's have different size/length axles. You can't run off the shelf chromos.
Post Posted: Sat Apr 14, 2012 12:55 pm
What about rear diff centre
Post Posted: Sat Apr 14, 2012 4:39 pm
Rear diff will hold up fine with a welded/spool carrier
Vehicle: 4wd
Post Posted: Sat Apr 14, 2012 4:44 pm
Welded rear is fine, but welded front is ghey (could suit the car well).
Watch out or you'll get sued.
Vehicle: 1985 Holden Drover
Post Posted: Sat Apr 14, 2012 5:19 pm
:lol: Armsup
1989 WT Sierra.
Post Posted: Sat Apr 14, 2012 10:54 pm
stockman wrote:
Welded rear is fine, but welded front is for real men
Fixed it for you :thefinger:
Post Posted: Sun Apr 15, 2012 4:54 am
so yes or no?
the only reason i ask how they go on the sand is because i launch my boat every weekend (on the sand)
Post Posted: Sun Apr 15, 2012 7:10 am
A welded front will suck on the sand and require chromo cv's and axles in a sierra. A welded rear will be fine.
Post Posted: Sun Apr 15, 2012 7:14 am
how will it act on the road?
Post Posted: Sun Apr 15, 2012 7:16 am
On the road it will suck on low speed corners and car parks with a welded rear, but thats what you get for being a cheap skate. Spend a bit more on an auto locker and it won't be so bad on road.
Post Posted: Sun Apr 15, 2012 7:25 am
how much are auto lockers?
will they fit a coily?
any recomended brands?
thanks
Post Posted: Sun Apr 15, 2012 7:41 am
thanks
The only option for a front lokka in a coily is welded... :cry: I can't imagine you busting axles and cv's in the sand
Post Posted: Sun Apr 15, 2012 7:43 am
Not sure what fit's a coily rear (that sounds so ghey), but Rusho should be able to enlighten us with his wisdom.
Post Posted: Sun Apr 15, 2012 7:50 am
Wisdom.... :rofl: :rofl: AFAIK the rear coily diff accepts everything that a leafy does. I will also add that your axels and cv's SHOULD be ok in the sand as long as you don't drive like a knob head.
Post Posted: Sun Apr 15, 2012 8:24 am
But locked on the sand heavy steering will still make it a pain in the arse I reckon, key to sand driving is momentum and that's hard to keep up whilst turning and avoiding obstacles etc with a locked front.
Post Posted: Sun Apr 15, 2012 8:48 am
any good brands of auto lockers
for my rear diff
Post Posted: Sun Apr 15, 2012 8:56 am
Welded front diffs suck immensely under all conditions.
Auto lockers suck a little bit in the rear. Spartan seem OK?
Steve
Post Posted: Sun Apr 15, 2012 10:58 am
4wd systems lokka brand is what I went with when I bought one cause they have a decent warranty and still cheap.
Post Posted: Sun Apr 15, 2012 11:07 am
how much is "cheap"
Post Posted: Sun Apr 15, 2012 3:41 pm
www.lowrangeoffroad.com
Post Posted: Sun Apr 15, 2012 4:25 pm
Steve
I barely know my Spartan is there and it has been faultless.
Post Posted: Sun Apr 15, 2012 4:56 pm
As another opinion I think welded front on the sand is no worse then a welded front on any other surface. I've done a dozen beach trips now with mine welded and I have no issues with steering. Really it only badly affects steering when your barely moving, but even that isn't as heavy as when on dirt or most other 4WD surfaces. I'll also mention that I haven't snapped any cvs or axles yet, and its wrong to assume a welded front diff will result in snapping them every other trip out. Your driving style and what you drive will have the most effect on that.
sierra 2" spring lift G13BB Front CIG locker
Post Posted: Sun Apr 15, 2012 5:01 pm
X2.
I ran welded both ends in my Sierra for around 10 years.
Was fine.
But after lucking out on a cheap lock rite for the front, I was much happier.
Welded rear stayed for life of the Sierra.
Users browsing this forum: No registered users and 48 guests
