| Author |
Message |
tanshi
 Posted: Sun Apr 22, 2012 7:28 pm |
Ok, i am in the process of planning my tray and roll cage on my LJ ute. i have run into a problem that im hoping those in the know on here can give me some advice on. As you will see in the pics below, the spare tyre takes up alot of the tray space. in front of it will be the fuel tank, (in the blue frame) My issue is this. the back stays need to be between 30 and 45 degrees. however in these angles sits the spare wheel so i cannot run the stays down to the top of the chassis. I would rather not move the tank or the spare. i can run the cage down the outside of the chassis rails and get the angles that i need. My question after that long description is. how should i best mount the back stays to the chassis??? i thought about drilling and crush tubing the chassis near the rear spring mount and running a heavy angle out ontop of the spring mount. In the future i would like to get this CCDA approved so needs to fit within their regulations im open to all suggestions though.
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Sun Apr 22, 2012 8:39 pm |
According to CCDA the backstays only have a minimum limit of 30 degrees theres no upper limit or are you basing the 30-45 degrees on something else.
_________________ Made in JP. Built in WA.
tanshi
 Posted: Sun Apr 22, 2012 8:41 pm |
45 degrees takes it to the end of the chassis.
Fatzook
 Posted: Sun Apr 22, 2012 8:51 pm |
Knock a tube through the rear chassis cross member, same as we do with the front ones on sierras. Plug weld along the length of the crossmember. This will give an 'outrigger' for the rear stay to make contact with. Brace as required.
I have a few ideas as to how you could make a very strong, but removable mount back there, but its hard to explain over the interwebs.
tanshi
 Posted: Sun Apr 22, 2012 8:55 pm |
oh nice i didnt think of that.!
removable would be better, I'll have to make time to chat to ya about it then wont i
Fatzook
 Posted: Sun Apr 22, 2012 9:25 pm |
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Mon Apr 23, 2012 12:57 am |
You could run a pipe down at 30°, put a 90° bend in it, and mount to the chassis with 4 bosses. I Use these at work. It's a bit of 20mm bar with a 12mm thread in it. Meaning you could use hex head bolts, counter sunk into the plate and no bolts on the other side. With a diagonal cross brace on these pipes it would be heaps string enough, and tight enough to go around your tyre. Does your rear axle move enough to touch the spare when flexing?
Fatzook
 Posted: Mon Apr 23, 2012 7:48 am |
31zook wrote: You could run a pipe down at 30°, put a 90° bend in it, and mount to the chassis with 4 bosses. I Use these at work. It's a bit of 20mm bar with a 12mm thread in it. Meaning you could use hex head bolts, counter sunk into the plate and no bolts on the other side. With a diagonal cross brace on these pipes it would be heaps string enough, and tight enough to go around your tyre. Does your rear axle move enough to touch the spare when flexing? I'm pretty sure that for CCDA, Rear stays cannot be bent. And although I doubt it would be an issue, mounting a plate in shear on the side of the rail is probably not a great idea for such a crutial member of the cage. i use threaded bosses for mounting number plates, removable panels, stauff clamps for hydraulic lines/ p/steer lines etc. I think welded crush tubes through the rail & fish plates would be a better solution if this were the chosen path.
tanshi
 Posted: Mon Apr 23, 2012 8:35 am |
31zook wrote: Does your rear axle move enough to touch the spare when flexing? I havent had it up to full flex but im hoping not. It has WT diffs and -28 wheels on it so i would think the offset would be enough to clear.
tanshi
 Posted: Mon Apr 23, 2012 9:40 am |
I thought about doing something similar to this the red would be 6-8mm plate folded to fit over the chassis, the back stay would run down to the horizontal bit between the gussets. green are verticle gussets. blue are crushed tubed bolts through the chassis.
