| Author |
Message |
jmd-247
Joined: Mon Apr 04, 2011 11:24 am Posts: 224 Location: THE BURGH!
 Posted: Fri May 11, 2012 2:22 pm |
Is the bell housing pattern the same from the jimny g13bb to the g13a?? Without having a look I wouldn't have a clue an all you more Suzuki educated people might no! I would expect them tO be tho?
I want to put in an auto box in the Sierra but quite happy being a slow poke with the smaller engine.
Any help appreciated
Josh
tanshi
 Posted: Fri May 11, 2012 2:32 pm |
yep its the same bell housing
its an electronic auto, thus none of the inputs in needs will be available from a carbie 1.3
you would be better off getting the jimny 1.3 and doing efi at the same time
Fatzook
 Posted: Fri May 11, 2012 2:36 pm |
tanshi wrote: yep its the same bell housing
you would be better off getting the jimny 1.3 and doing efi at the same time X2.
jmd-247
 Posted: Fri May 11, 2012 3:54 pm |
Spewing! Thanks guys I thought that would be the case somehow!
JrZook
 Posted: Fri May 11, 2012 3:56 pm |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Fri May 11, 2012 5:18 pm |
Fatzook wrote: tanshi wrote: yep its the same bell housing
you would be better off getting the jimny 1.3 and doing efi at the same time X2. X3. Much easier than trying to make the auto work with the carby. Steve.
KEENSY85
Joined: Wed May 09, 2012 12:46 am Posts: 1742 Location: north brisbane
Vehicle: 1985 lwb sierra UTE
 Posted: Sat May 12, 2012 8:20 am |
Or just go with the 5 speed it will fit and u could use a manual pedal assembly providing there still cable not hydolic on the g13bb
_________________ Green? greeeen is nice !
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sat May 12, 2012 8:28 am |
He wants the auto.
_________________ mlm
KEENSY85
 Posted: Sat May 12, 2012 8:36 am |
No shit just thinking about options,I know Sierra auto are rare as, jimny manual would be cheaper ae no engine swap
SierraDan
 Posted: Sat May 12, 2012 8:39 am |
But he wants the auto.
Gwagensteve
 Posted: Sat May 12, 2012 8:42 am |
KEENSY85 wrote: I know Sierra auto are rare as G13BB Jimny autos are rare as. Sierra autos don't exist. The only Sierra autos were f6/K6 engined 660cc japanese market cars. They are a three speed and would, I think, be terrible. Steve.
gregc
Joined: Wed Sep 21, 2011 9:09 am Posts: 177 Location: melbourne
 Posted: Sat May 12, 2012 8:51 am |
Jmd - if you already have the auto and decide not to use it, i'm happy to take it off your hands  If you are set on keeping your carb 1.3 then you might want to check out a vitara 3 speed install (with or without the 1.6L carb engine swap), or step up to a 1.6L EFI with the 3 or 4 speed vitara autos.
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Sat May 12, 2012 9:38 am |
There's a lucky 13 adapter kit in the for Sale section so you can achieve this.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Sat May 12, 2012 10:46 am |
KEENSY85 wrote: Or just go with the 5 speed it will fit and u could use a manual pedal assembly providing there still cable not hydolic on the g13bb why would he want to put in a jimny manual gearbox in his car, when he already has a manual gearbox to start with, he wants a auto  unless the jimny manual is stronger then sierra gearbox then theres no point at all.
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
jmd-247
 Posted: Mon May 14, 2012 11:23 am |
gregc wrote: Jmd - if you already have the auto and decide not to use it, i'm happy to take it off your hands  If you are set on keeping your carb 1.3 then you might want to check out a vitara 3 speed install (with or without the 1.6L carb engine swap), or step up to a 1.6L EFI with the 3 or 4 speed vitara autos. There was one being wrecked out not far from me and if it was going to work (which i didnt think it would) i was going to use it. unfortunately its gone now, otherwise i could have helped you out with it. Ive now decided to go the 16b swap with a 3 speed auto. i have no problems doing the injection swap would just rather stick with carby for some reason! Thanks for the info guys! josh
Fatzook
 Posted: Mon May 14, 2012 11:43 am |
Gwagensteve wrote: Sierra autos don't exist. Sorry mate, but I disagree. Autos were available as an option here, and off the shelf in japan. I fitted an import coily motor and auto to this bad boy.
Gwagensteve
 Posted: Mon May 14, 2012 12:15 pm |
I can't comment on an import coiler - it wouldn't surprise me if they were available as an option in Japan with a G13, but I have never heard of or seen an auto Australian delivered sierra. I also bought all the Australian 4WD mags right through the period the Sierra was on sale and never once saw one referred to on a price list, reviewed or mentioned. I have seen some weird stuff reviewed too, like a WT high roof in overlander magazine in late 1988.
Has any one else seen or heard of a factory sierra auto?
Does anyone have any more information about this?
Fatzook
 Posted: Mon May 14, 2012 12:25 pm |
I've seen 3 in total. One was the front cut import, one was an aussie delivered factory SJ80 auto, and one was a WT sierra.
I guess that it is possible that the WT was an import jimny, but it was not badged as such.
Also the import coiler auto was a 3sp.
