It is currently Fri Sep 18, 2026 10:02 pm
Vehicle: Vit
Post Posted: Wed Jul 25, 2012 11:28 am
Hey guys
Ok so with a 3" lift for my 97 Vitara do I need to lengthen the brake lines and do a rear axel spacer (http://www.bits4vits.co.uk/store/vitara ... od_42.html) or can I get away without doing both?
im planning on puttin something like these in the back: http://www.bits4vits.co.uk/store/vitara ... d_173.html with 1.5" spacers
and doing a strut mount flip with 15mm spacers in the front. Also doing a diff drop to save my CV's
I currently have a 40mm spring and shock lift.
is there anythingelse I need to account for?
thanks!
- Charlie
Post Posted: Wed Jul 25, 2012 4:55 pm
You can probably get away with unclipping brake lines, but for the small cost I'd say it's worth getting some longer braided lines at least for the front.
Rear driveshaft spacer definitely a good idea.
Otherwise get a pair of camber bolts if you don't already, and book in for a wheel alignment.
Vehicle: Vit
Post Posted: Wed Jul 25, 2012 5:17 pm
Do you know where I can get some cheap brake lines from? Thanks for that mate!
Post Posted: Wed Jul 25, 2012 5:33 pm
go see Power Brakes SA at Gilles Plains, just up from the Holden Hill Cop Shop on the otherside of the road.
Vehicle: Vit
Post Posted: Wed Jul 25, 2012 6:45 pm
Okey dokey sounds good, also should I extend my bump stops? with the back control arm spacer what would happen if I didnt put one in, would it hurt anything?
thanks agian!
Post Posted: Wed Jul 25, 2012 9:00 pm
The rear drive shaft is on a slip yoke at the transfer end. Lift increases the distance from the transfer to the diff, so at full droop the drive shaft can slide off the transfer output.
Bump-stops will depend on how things clear with it all fitted - if the shocks bottom out or the springs bind, or if the tyres scrub on guards longer bump-stops can help.
Vehicle: Vit
Post Posted: Thu Jul 26, 2012 7:45 am
okey dokey axel spacer sounds pretty good incurance then =P
thanks :D
Vehicle: Vit
Post Posted: Fri Jul 27, 2012 12:14 pm
Hey dark horse just reading^ did u mean this http://www.bits4vits.co.uk/store/vitara ... od_26.html when you said driveshaft spacer? I think I thought u meant rear control arm spacer :)
Thanks,
Post Posted: Fri Jul 27, 2012 1:51 pm
That is a driveshaft spacer, bolts between the shaft flange and the pinion flange.
Rear control arm spacer (usually called balljoint spacer) bolts between ball joint of rear control arm and top of diff. Allows more downtravel before balljoint runs out of movement. Also a good idea if you're lifting 3" or you'll flog it out pretty quick.
Vehicle: Vit
Post Posted: Sun Jul 29, 2012 10:35 am
thanks that makes more sense now =P ^^
Im just looking at diff drop brackets (http://www.ebay.com.au/itm/320951787290 ... 1438.l2649) and im just wondering if you can use the same bolts that were already there/is there anything I need to know or are they all pretty standard when buying and fitting?
thanks again
Post Posted: Mon Jul 30, 2012 8:35 pm
Same bolts are fine, as long as you don't trash them getting them out or back in.
Otherwise it's a simple but shitty job - front up with stands under chassis, jack under diff to take load off bolts. Stock brackets out, new ones into upper mounts. Lower diff on jack until lower bolt holes line up. Repeat ad nauseum until they all line go in.
Users browsing this forum: No registered users and 62 guests
