Joined: Sat Apr 30, 2011 4:01 am Posts: 25 Location: Moruya NSW
Posted: Sun Jul 22, 2012 2:20 pm
Hi All,
Back again. I am running 30" Nexen AT II's on my unlifted Vit. With a load in the back or at speed the rear shocks are compressing enough that the tyres are rubbing up inside the rear wheel arches. Can I put in a set of HD rear shocks to compensate for this or will coils be required as well? If funds allow I am looking at fitting a 35mm suspension lift upgrade, but for now I was wondering if heavier duty shocks will fix problem.
Posted: Sun Jul 22, 2012 2:32 pm
Thnx! I'll save the dollars for the shocks and put it too a complete kit. Any ideas on something middle of the road, not too exxy not cheap crap!! Only want to do coils and struts, about 30-40mm lift.
hi i put a 1 inch lift in mine only caz i got it for $100 .any how i also run 30x 9.5 maxxis and have no issues scrubbing out not even at full lock. personally if i was doing it again tho i would go a 2 inch lift
Users browsing this forum: No registered users and 214 guests
