It is currently Thu Nov 05, 2026 8:42 am
Vehicle: 2000 suzuki jimny
Post Posted: Wed Aug 01, 2012 9:02 am
just wondering if i put a 4" spring lift in my jimny would i b able to run 31 or even 30s and b able to flex really well without cutting guards
Vehicle: 4wd
Post Posted: Wed Aug 01, 2012 9:04 am
Subscribed 8)
Watch out or you'll get sued.
Post Posted: Wed Aug 01, 2012 9:06 am
No youll need to cut the guards
Post Posted: Wed Aug 01, 2012 9:16 am
what about 30"
Vehicle: 2018 DMAX
Post Posted: Wed Aug 01, 2012 9:56 am
Spring lift doesnt help you fit bigger tyres. If the tyre hits on stock springs, it will hit with 5" springs. Bump spacing is what you need.
Post Posted: Wed Aug 01, 2012 1:30 pm
guard chop, correct rim offset and bump stop spacing will all need to be adressed to fit 31's. There are alot of people running 30's and 31's on jimny's, put in a bit of effort and do a search through the rigs section, you'll find lots of info in there.
Are you planning to adress the issue of gearing if you fit 31's?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Aug 01, 2012 6:52 pm
30's will still need a guard chop, I had to cut a bit out to make mine fit
Post Posted: Wed Aug 01, 2012 7:23 pm
Guard chop and bumpstop spacers. 235's will fit with no lift (98-05 with stock bumper) , 235's with a 80mm lift rub - Go figure :lol:
Rim off-set of important. My tyre's use to rub on the coil tower on the front with 31's and a 4" lift, but they didn't for other people :roll: If i was to do it again i would go 50mm spring lift, chopped guards, bumpstop spacers and longer shocks...for 31's that is....
Post Posted: Thu Aug 02, 2012 4:53 pm
stockman wrote:
Subscribed 8)
x2
Post Posted: Fri Aug 03, 2012 10:55 pm
alright iv got some decent offset rims got the 50mm lift ordered and will b here this week body lift just need female bolts. if i need to chop for 30 than i might as well do it so i can run 31s hell lets chop enough for 33s..... how much are guard chops these days any way
Post Posted: Fri Aug 03, 2012 10:59 pm
How much is a grinding disk? :roll: you will need to hammer the shit out if the fire wall to...
Post Posted: Fri Aug 03, 2012 11:25 pm
hahahahah i like the way you think iv got a die grinder and everything i just like the look of my jimny its still all nice and tidy
Post Posted: Fri Aug 03, 2012 11:43 pm
You'll want a 4" or 5" angle grinder..
Post Posted: Sat Aug 04, 2012 4:44 am
Buy cheap plasma cutter on ebay
Best thing ever for guard chop
Post Posted: Sat Aug 04, 2012 10:00 am
havnt used a plasma cutter b4 no someone with one will it burn paint
Post Posted: Sat Aug 04, 2012 10:11 am
Yes. But in the concentrated area.
Post Posted: Sat Aug 04, 2012 11:45 am
dont want to use anything thats going to burn my paint might just mark out where im going to cut off and then die grind it off
Post Posted: Sat Aug 04, 2012 12:03 pm
electric hacksaw
Post Posted: Sat Aug 04, 2012 1:15 pm
You need one of these... http://www.ebay.com.au/itm/CNC-Waterjet ... 1c23dc798e
Pretty much anything that moves to cut will burn your paint to some degree, a jigsaw might be about the least heat generative.
Made in JP. Built in WA.
Post Posted: Sat Aug 04, 2012 1:28 pm
Air body saw or reciprocating saw.
Post Posted: Sat Aug 04, 2012 3:29 pm
iv got one of those saws there not that great what do they use at the panel beaters
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Fri Aug 10, 2012 6:20 pm
Don't do the plasma cutter thing! Have you ever seen a burnt out car? Apply heat= instant rust! I've done the gaurd chop and I used a jigsaw for the plastics and tin snips for the gaurd. Don't forget to re touch up painted surfaces so no rust develops. As for the 4" lift..... DON'T do it! I have a 3" suspension lift in my Jimny and honestly off road it's a weapon! On road it's like jelly on a plate! I have big $ fully adjustable shocks and yes they stiffen up the stroke of the suspension but it's the sideways sway warble shit that's the killer! Just a tad to high in my opinion and whilst the terrain I wheel in is severe rutted, big drop off/step up, rocky, deep mud bogs etc I am unsure as to the extra 1" of clearance and travel is worth my car handling like jelly on a plate. So much so that I am in the middle of whacking reduction gears, bighorns, and calling it a weekend warrior as the daily thing is a little tedious now. BUT did I mention OFFROAD? Thing is an absolute weapon with swaybar disconnected, 3" lift and tyres,soon to be double locked it is unstoppable! Depends really on what your after but realise this.... The zooks although are very capable they are not a Jeep,pootrol or cruiser and do not weigh in at 2t plus! Massive lift will give lots of clearance but because car is light the springs are like slinkies or hard as fu@k and either bad back and won't work or work well and jelly on a plate on the blacktop. Be warned! Your choice, your car. I also have a brand new complete 2" body lift sitting in my garage but honestly.... I AM scared to fit it! With such a short wheelbase and narrow track.... Without BIG offset rims, big tyres and wheel spacers.... Rollover is imminent! I know I done mine 2 weeks ago without the body lift!
Post Posted: Fri Aug 10, 2012 10:09 pm
Red Jimny = 3" body lift + 2-3" suspension + 31s. Looked scary to me and made mine look small.
Users browsing this forum: No registered users and 72 guests
