It is currently Fri Nov 06, 2026 3:01 am
Vehicle: 99 SJ80 Coily SR20DET
Post Posted: Sun Aug 12, 2012 6:54 pm
Hey guys I'm in desperate need of coily rear trailing arms, the more sets the better for my up coming Trials season.
Thanks
Rhys
Post Posted: Sun Aug 12, 2012 9:41 pm
Thanks
Rhys
Sucks you can't make better ones, or atleast laminate the OEM arms. :(
Post Posted: Mon Aug 13, 2012 9:30 am
I've tried all sorts to over come but have ended up in the same predicament everytime, which is kicked out of class.
Next thing to try is flog out middle bush and put in new nolathane bushes into front and back, and make sure my top link has no forward or backward movement, this should hopefully make it behave more like a four link
Post Posted: Mon Aug 13, 2012 12:28 pm
Could you run a uniball/ jonny joint arrangement? There may be one that fits, if I recall, the ID of the bush sleeve on the jimny/ coily arms is about 51mm, so a 2" joint should work. You may need a couple circlip grooves machined in to retain it, but the arm itself will be essentially un-altered.
http://www.polyperformance.com/shop/Uniballs-p-202.html
http://www.polyperformance.com/shop/Johnny-Joints-p-16765.html
Post Posted: Mon Aug 13, 2012 1:30 pm
I'm pretty sure pootrol rear trailing arm bushes will fit.
Post Posted: Mon Aug 13, 2012 2:09 pm
sweet as will have a look, i've got two arms so far but will need at least four more for the season
Post Posted: Mon Aug 13, 2012 3:02 pm
do you bend/break them?
Post Posted: Thu Aug 16, 2012 4:59 am
Patrol are 50mm
Post Posted: Thu Aug 16, 2012 8:21 pm
I incased mine with 5mm plate it made them almost indestructible zookimonster has them he will prob sell them now that he has gone 4 link he ran multiple rounds of coopers rally with them. I only sold them to him because I put Jimny ones in they are 100mm longer so had to cut chassis mount and move it fowards but they are easier to get and a bit stronger. I am doing Logan challenge with him this weekend I will ask him how much
Users browsing this forum: No registered users and 22 guests
