It is currently Wed Oct 14, 2026 5:51 pm
Vehicle: Sj51t
Post Posted: Sat Sep 15, 2012 6:02 pm
Soo
I have had nothing but pobs with my vitara
1st was not revving up
Was fuel pump a blocked fuel filter
Then was out wheeling and it just stopped wood not start
Got it home worked out no spark!
Dizzy cap was bad looking
So I got new cap and button
Clean afm with right stuff and all intake ect
New plugs
And it was going running good really good,
But then just stopped
And will start but won't rev had a really bad miss like thing happing shaking whole car then it wil die 0 rpm then rev up a bit then die!
Missing when idling really just running like a box of poo
Now check eng light comes on
Best I can really explain
Pulled dizzy cap off for a look had white power like stuff in it a a mark on casing?
Plugs black there about 3min running time old!
Any help at all will be good
Not sure what to do now
Post Posted: Sat Sep 15, 2012 6:07 pm
Check the trouble codes using the check engine light - that's the first step.
Vehicle: Sj51t
Post Posted: Sat Sep 15, 2012 6:09 pm
How do I go out about this?
Post Posted: Sat Sep 15, 2012 6:20 pm
You'll need access to a FSM, but jump the correct terminals on the diagnostic plug under the bonnet and the CE light will flash a code corresponding to the fault the computer is seeing. There are downloadable FSM's available on line.
I have an FSM for a pre 1995 vitara EFI but the 97 is completely different. (i.e the plug/terminals are different and the codes aren't the same)
Vehicle: Sj51t
Post Posted: Sat Sep 15, 2012 7:33 pm
Ahh yeah
Not real good with that kinda thing
Might just take it some where
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Sun Sep 16, 2012 7:22 pm
Double check your spark plug leads.... Had similar problem with 97 efi vitara and a cracked lead was the culprit.
Post Posted: Sun Sep 16, 2012 7:42 pm
What sort of mark in the cap? Could it be the rotor hitting? Check the cap is sitting concentric.
Vehicle: Sj51t
Post Posted: Sun Sep 16, 2012 9:43 pm
Brand new leads about 2 week old
Yeah it was the rotor button can see on button where it has hit?
Going buy brand new dizzy if cant get used one in next few days and maybe a used afm just to have incase and
Just towing it to shop and bend over
Vehicle: Sj51t
Post Posted: Tue Oct 02, 2012 4:06 pm
So it's the coil in the dizzy
Really need a g16b dizzy!
Or going to have to get new nor for 360 dollars
Users browsing this forum: No registered users and 247 guests
