| Author |
Message |
Zuzukie
Vehicle: 82 1ltr, 93 1.3 with 6.5's
 Posted: Fri Sep 28, 2012 9:27 pm |
Heya Wanting to install a dual battery system into my 93 wt but not 100% sure on how to install it Just want to do a cheap and basic setup Car has had an upgraded alternator but not sure what alternator has been installed Any ideas or suggestions will be a great help
rhino85
Joined: Sun Nov 06, 2011 9:42 am Posts: 49 Location: Far North Coast NSW
Vehicle: 1985 sj50v SWB
 Posted: Fri Sep 28, 2012 9:37 pm |
I'm not an expert but I have an in line dual battery set up which uses no isolator or switch just a second battery on the other side of the engine bay and big fat dual battery cables running between terminals and hasn't given me any grief and works well for the winch and other accessories
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Fri Sep 28, 2012 9:58 pm |
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Dec
 Posted: Fri Sep 28, 2012 10:34 pm |
Hey mate, this may interest you in a cheap easy do it yourself duel battery tray I first purchased one of these http://www.supercheapauto.com.au/online ... escriptionI used the lid only as it is the perfect width of a 58 Century battery, i then simply got a pair of tin snips and rubber mallet and cut the size i wanted and hammered the corners and pot-riveted it all together. Hope that helps
jimny_timmy
Vehicle: Suzuki Jimny 2010
 Posted: Sat Sep 29, 2012 5:37 am |
There's redarc isolators on eBay for reasonably cheap... I think I have a spare one liking around here if you're interested?
Gough
Vehicle: 99 JLX Suzuki Jimny
 Posted: Sun Sep 30, 2012 7:22 am |
Zuzukie
 Posted: Sun Sep 30, 2012 9:02 am |
Got some ideas now So do i need to join both terminals on both batteries or can i just connect the positive terminals nd earth out the second battery to a spot on the body Ive got a tray from super not so cheap at all just gotta get some cable Does it work better with an isolator switch nd is it needed
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2659 Location: Georgetown, Guyana
 Posted: Mon Oct 01, 2012 2:15 am |
How you wire depends on why you're adding the second battery.
The primary reason to add a second battery is for additional capacity, some people want to use that capacity for longer run time - fridges, etc - with the engine off, and to avoid draining the cranking battery - in which case an isolator is needed - other people want to use that capacity to provide greater current for winching etc., - in which case you can just parallel them.
