| Author |
Message |
KEENSY85
Joined: Wed May 09, 2012 12:46 am Posts: 1742 Location: north brisbane
Vehicle: 1985 lwb sierra UTE
 Posted: Thu Nov 01, 2012 6:56 pm |
Any tricks to installing king pins and shims?
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu Nov 01, 2012 7:24 pm |
12mm socket. Chisel/Screwdriver/Punch Hammer.
_________________ mlm
Bruce
Joined: Sun Jun 11, 2006 11:30 pm Posts: 4003 Location: Brisbane
 Posted: Thu Nov 01, 2012 8:03 pm |
Fish scales
_________________ [quote="royce"] I wouldnt mind insulating my rear
KEENSY85
 Posted: Thu Nov 01, 2012 8:35 pm |
Lol wt? I got them apart fine and will be able to put it all back together. but I noticed they were shimmed so I'm trying to work why they were shimmed or are they all shimmed?
Blkfxx
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
 Posted: Thu Nov 01, 2012 8:40 pm |
There needs to be a certain 'preload' on the bearings, The shims help set the correct setting. The fish scales will give you the reading. Have a read through the FSM, Very clear.
_________________ Quote: I like the tuna here
KEENSY85
 Posted: Thu Nov 01, 2012 9:06 pm |
I should have done that first (read theFSM) { thanks guys)
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Fri Nov 16, 2012 7:14 am |
I,ve had fitter play with mine.No good.
What's FSM ?
Thanks.
Bye
mrw82
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
 Posted: Fri Nov 16, 2012 7:35 am |
cairns27 wrote: What's FSM ?
Bye
Fucking service manual Bye
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Fri Nov 16, 2012 7:48 am |
cairns27 wrote: I,ve had fitter play with mine.No good.
What's FSM ?
Thanks.
Bye There is your problem. Fitters replace components and mechanics rebuild components. If you are fixing bearings fitter style then ya need to buy a new assembled diff assembly and replace the lot. Mechanics can replace indervidual bearings.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Sat Nov 17, 2012 9:25 am |
shep wrote: cairns27 wrote: I,ve had fitter play with mine.No good.
What's FSM ?
Thanks.
Bye There is your problem. Fitters replace components and mechanics rebuild components. If you are fixing bearings fitter style then ya need to buy a new assembled diff assembly and replace the lot. Mechanics can replace indervidual bearings.  You really need to define who you are talking about shep. A fitter is in maintenance and manufacturing, building and machining whatever is needed. A bullbar fitter is not.
