It is currently Fri Sep 18, 2026 9:50 pm
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4  Next
Vehicle: Suzuki jb43 jimny
Post Posted: Fri Nov 02, 2012 11:18 am
I no haha I just want to start it already haha : P hopefully he response before 5 so I can get to.the bank ... Fingers crossed
Post Posted: Fri Nov 02, 2012 4:44 pm
maybe he started the beers before the work, I'd offer too except im crook at the mo, im western burbs, but hallet cove is a doable bike ride too :D
Shorty Vit is it? me and a mate did mine in a couple of hours, with 1 trolley jack a scissor jack and a few blocks of wood, but hes a panel beater and i was an apprentice mechanic at the time
Post Posted: Fri Nov 02, 2012 11:33 pm
Yer lil swb and thanks for the offer I gotta get the lift first my bsnks bloody stupid I tell ya. Guess we will se once I get the body lift
Post Posted: Sat Nov 03, 2012 10:23 am
Body lift is sorted Armsup thanks to a great cuz of mine
Post Posted: Sat Nov 03, 2012 5:37 pm
Atari I Norene calling on your help, when would u be free
Post Posted: Sat Nov 03, 2012 5:54 pm
norene WTF? :?
might be able to help not this weekend coming up, but the next?
not sure if it's been mentioned, but you'll need a 24mm socket for the female bodylift bolts.
read the instructions, they're pretty good + with what everyone has said here you'll piss it in... i know there is a girl on here fitted one of greg's vitara bodylift kits, without instructions! Armsup
Post Posted: Sat Nov 03, 2012 8:33 pm
That's was ment to be I may be lol and shit I better be able to do it haha will start it as soon as I have it, it should all go well and hopefullyeverything with brake lines goes well how long did urs take how hard did it take to modify your bumpers
Vehicle: WT'd SJ410 G16B
Post Posted: Sun Nov 04, 2012 7:28 am
Talking about the female bolts. Where can I get some of them?
Post Posted: Sun Nov 04, 2012 7:37 am
buy a kit from BYE Products the business directory & they come supplied free with body blocks. :wink:
Post Posted: Mon Nov 05, 2012 6:15 pm
How did u all go with moving the bumpers
Post Posted: Mon Nov 05, 2012 6:20 pm
50mm box section cut & drilled to suit.
Post Posted: Mon Nov 05, 2012 7:31 pm
:) sweet was hoping it would be simple, will have to search some threats for some pics and shit
Post Posted: Wed Nov 07, 2012 4:23 am
Since I've got Photobucket open anyway...
Front is a little more complicated, but the two top bolts are the same theory.
Post Posted: Wed Nov 07, 2012 6:30 am
Well thank you very much, I had found that pic on your forum but couldn't work out where the blocks where :), in a update body lift is arriving today and will start tonight
Post Posted: Wed Nov 07, 2012 9:06 pm
What's it mean by undoing the steering colum on a body lift :/ bot entirely sure so thought I should ask
Post Posted: Wed Nov 07, 2012 9:12 pm
in the engine bay there are 2 uni joints on the steering shaft, on at the steering box & the other at the firewall. there is a splined section that they attach to, on the 2 uni's there is a rubber boot & a bolt on each uni joint to clamp them onto the spline on the box & the shaft that comes through the fire wall.
loosen both of these off & give the splined section a spray with WD40/RP7
Post Posted: Wed Nov 07, 2012 9:17 pm
Thank you very much Gus, once again a great help got up to that tonight in 3 hours : P rest is being worked on : D
Post Posted: Wed Nov 07, 2012 9:21 pm
pics down the bottom of this thread show the boot & bolt pretty well on the box end http://nbs4x4club.com/forum/index.php?topic=10880.0
Post Posted: Wed Nov 07, 2012 9:32 pm
:) Thank you will work on it tommow night : D
Post Posted: Fri Nov 09, 2012 5:37 am
Is there anyone that can help me out tonight doing this :) really need some help I'm trying to get the right hand side one in behind the left wheel and I can't get it
Post Posted: Fri Nov 09, 2012 9:03 am
i'm working tonight :(
which one is it, the back left one on the right hand side :lol:
Post Posted: Fri Nov 09, 2012 9:52 am
It's like where he door hingers are on the right side, mite try lifting it different
Post Posted: Fri Nov 09, 2012 9:53 am
drivers side door or the tail gate :?
Post Posted: Fri Nov 09, 2012 11:53 am
Drivers side there are break lines near it that can't be moved
Post Posted: Fri Nov 09, 2012 12:04 pm
brake lines shouldn't be a problem, have you unbolted the brake distribution block from the chassis rail? 2 small bolts in the middle of it have been removed in the pic
also unclip the speedo cable.
Post Posted: Fri Nov 09, 2012 12:15 pm
Armsup :) will do that and see how I go tonight how are u such a wealth of knowledge
Post Posted: Fri Nov 09, 2012 12:19 pm
i know stuff about things :P
you've undone both uni's on the steering shaft?
once the lift is in you should be able to bolt it back up as per normal, might need to tweak the lines a bit... BE CAREFUL NOT TO DAMAGE OR KINK THEM!!!!!!!!
Post Posted: Fri Nov 09, 2012 12:21 pm
I actually can't get to both uni bolts so iv undone it inside and ill look into that and make sure I don't :)
Post Posted: Fri Nov 09, 2012 12:26 pm
i don't think inside is going to work, as thats a separate shaft that isn't effected by the BL.
did you try turning the steering wheel to get bolt in an easily accessible position & then take the key out to lock it with the steering lock.
Post Posted: Fri Nov 09, 2012 12:56 pm
Will do that tonightt as well :)
Users browsing this forum: No registered users and 213 guests
