It is currently Tue Sep 22, 2026 8:45 am
Vehicle: Coil Sierra
Post Posted: Fri Nov 16, 2012 5:25 pm
How does the plate behind the plastic trim come off? Looks to be tacked on.
Post Posted: Fri Nov 16, 2012 5:29 pm
There are spot welds, best way to remove them is with a spot weld drill bit.
Vehicle: LWB Sierra & XL7
Post Posted: Fri Nov 16, 2012 5:30 pm
Grinder.
Drill it out and obviously you'd be left with holes.
'92 Vitara & Camper trailer
Post Posted: Fri Nov 16, 2012 5:33 pm
Its a special drill bit, if you do it right there won't be any holes, would much prefer that than something that makes lots of sparks near your nice paint.
Post Posted: Fri Nov 16, 2012 5:35 pm
you'll need a spot weld drill bit, costs about $12 from auto paint shops.
Post Posted: Fri Nov 16, 2012 5:53 pm
never even knew they existed
Post Posted: Sat Nov 17, 2012 2:52 pm
That would have been better then welding up all the holes
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Nov 17, 2012 3:47 pm
I'd still grind them, or practice first u can still drill all the way through
Vehicle: SJ80, SE416
Post Posted: Sun Nov 18, 2012 9:17 pm
Trade tools have spot weld bits. I paid about $20-25 ea. for mine.
Judging by the wear on my set, I used a 6.5mm spot weld bit to remove my coily sills.
Don't do that - if you use a 6.5mm bit and are very precise I found you are left with just a tiny bit of weld that can be broken off easily.
I only drilled through 1 when I tried an 8mm bit!
Vehicle: 1995 Sierra 1.3
Post Posted: Tue Nov 20, 2012 3:27 pm
I ground mine, worked well, but obviously you need to used some filler to smooth off the grinder marks, even the really small ones. I would use the spot weld drill tip if I ever did it again.
Post Posted: Tue Nov 20, 2012 6:47 pm
well thanks for the help, i think i will use the 6.5mm bit, not fussed on how it turns out as i plan to paint 100mm from the bottom up in black.
Users browsing this forum: No registered users and 210 guests
